Hub disconnect issues
HI Tom,
I now have 2 Xiaomi sensors that goes inactive. In between they do not start reporting battery. They were right next to the hub. What can it be. See the log of event. After one hour of no-motion they go inactive, I assume eventually will be declared off-line?
Date Source Type Name Value User Displayed Text
2017-12-10 10:12:37.087 AM GMT
1 hour ago DEVICE motion inactive Extension Motion motion is inactive
2017-12-10 10:10:37.478 AM GMT
1 hour ago DEVICE motion active Extension Motion detected motion
2017-12-10 10:10:37.497 AM GMT
1 hour ago DEVICE lastMotion 2017 Dec 10 Sun 10:10:37 AM Extension Motion last motion is 2017 Dec 10 Sun 10:10:37 AM
2017-12-10 10:10:37.470 AM GMT
1 hour ago DEVICE lastCheckin 2017 Dec 10 Sun 10:10:37 AM Extension Motion last checkin is 2017 Dec 10 Sun 10:10:37 AM
2017-12-10 9:58:45.057 AM GMT
2017-12-10 9:56:45.819 AM GMT
1 hour ago DEVICE lastMotion 2017 Dec 10 Sun 9:56:45 AM Extension Motion last motion is 2017 Dec 10 Sun 9:56:45 AM
2017-12-10 9:56:45.794 AM GMT
1 hour ago DEVICE lastCheckin 2017 Dec 10 Sun 9:56:45 AM Extension Motion last checkin is 2017 Dec 10 Sun 9:56:45 AM
2017-12-10 9:56:40.175 AM GMT
I am also experiencing disconnects and reconnects every 1 minute and I can’t find any method to resolve this.
Grateful for any advice to help stop this problem
I seem to be having the same issues for the last couple of weeks on my V1 hub. I thought it was a bad router or something with my internet and after eliminating those I started looking at the hub…
It connects and disconnects continuously and is driving me nuts. Ive been in the IDE, read the events, rebooted, shut everything off, unplugged everything and currently do not have any idea what to do next.
Do we know what version of firmware I should have for V1? Do I need to open a support ticket?
Thanks in advance for any help.
Hi. I managed to reset my hub (V2) yesterday and so far, all is working fine and no disconnects. Not an ideal fix though as it is hard starting from scratch again
After suffering through that for too long, I can confirm that the hub disconnects have been fixed or at least largely mitigated in the next release of the hub firmware.
Did they bump you to the 0.20.11 firmware already as part of the Z-Wave firmware upgrade they performed on your hub the other day?
Yes they did. They also pushed a firmware update to the Z-Wave module. I had to reconnect about 2 dozen Z-devices afterward but I don’t believe that’s directly attributable to the either firmware upgrade.
I believe the loss of devices was more due to the very frequent power cycling that had been happening for days as well as the ST the cloud outage last week.
The update is impressive in terms of performance anyhow. One of the more significant I’ve seen so far.
Z-Wave devices respond faster than they ever have. I have also completed upgrading firmware on all 44 Iris SmartPlugs too. That was a long process as each had to be paired with Iris and left overnight but the result is the Z-Wave repeaters in these pair more reliably than before and stay connected afterward.
Looks like having my V1hub unplugged for a day did the trick for me. I also think that I had a device on the network creating an unstable situation that was handled when I took everything offline and began adding one by one.
Not sure what was creating the havoc but at least my hub is stable.
My Hub(v2.0) has been disconnecting several times a day for the last several days. I think it started on Thursday 1/25. Is anyone else having an issue?
Dave
I am having the same on my V1 hub.I also have problem pairing again all my 4 fibaro door/window sensors.
FYI: European V1 kickstarter backed hub 868MHz
The firmware update caused some kind of communication issue with my
router…I rebooted it and have not had an issue.
Dave
Agree with David. Rebooting with the hub utility certainly quieted things down. Been getting lots of disconnect messages and losing connections with z wave devices ever since setting up my hub last week. After the reboot, all is well. Using a v2 hub.
My V2 hub is disconnecting about once a week. usually comes back after I unplug it and pull a battery. It’s a pain because it always seems to happen in the middle of the night and I get a push notification that wakes me up. Is there a reset that can be done without having to add all of my things and routines? Is there something else I should be looking at doing?
You can try rebooting it in IDE ( https://account.smartthings.com )
click on My Hubs
select View Utilities
in the Hub Commands section - click on Reboot Hub
My issues have resumed. Thought the reboot was all it needed but not so. Now does no good. Started just before the recent outage. I wonder if all the disconnects and reconnects might be causing the overloaded cloud service? Kinda like a memory leak that grows until a crash.
Figured this out. I had moved the hub upstairs after the first episode and the connection to my router via Powerline Ethernet extension clearly wasn’t strong enough. Moving the hub back downstairs has it running like a clock now. No disconnects. So hub reboot if nothing else has changed and it starts acting up. Otherwise, suspect a bad internet connection.
Same here. No devices since March 16, 2018.
No attempts to connect/reconnect devices work.
I’ve been having the same issue for the last week or so. I’ll get a notification on my phone that my hub is offline, however, my Internet is up and I can access the Smartthings app. Google Home is linked to my hub and that is how I control my Wemo devices (I don’t have Wemo linked directly to Google Home) and I’m still able to control my Wemos through Google Home (and subsequently through my ST hub) when the hub is “offline”.
I had the same problem this week. I was away on business the alerts were at first troubling, then concerning then just annoying after I saw all was well. months ago I had to disconnect the health feature due to crashing.
i’ve gone through those same feelings today and this morning I hit the annoyed emotion.
