How to setup a brightness trigger?
I am trying to set up a condition like this:
If bulb A’s brightness is 100%, then turn bulb B on, else turn B off.
Is this possible by using CoRE or others?
Thanks.
I don’t use CoRE but I do use webCoRE all the time.
You can absolutely set this up on that platform. There’s a command for Level which you could check and then act accordingly.
There is also a community created app available on the forums. (Dim with me)
This app will set brightness levels base upon a switch or a bulb brightness + ON state.
