OR-IF commands im webcore
I use a lot of or if commands in the old core version. However in webcore I can’t figure out. I have quite a few dimmer switches that basically when I execute a routine I want them of off to set level to 100(done this no problem) however I want if the routine is executed and level is >1% to turn off. Can’t figure out how to do this
Nested If statement.
On (event you want to check) then check something g else.
If routine x executes
Then
If dimmer y. Level <= 1 then
Do a thing
Else
Do a different thing
Endif
Else
Do nothing
End if
And forgive my indents the community website killed them…
I haven’t tried this command so many different ways and no matter what it doesn’t work
I tried this and it does nothing at all
This seemed to get it to do what I want for now. I’m sure I’ll be back with more questions at some point. Webcore is confusing to me lol
You should check out the webcore community forum at https://community.webcore.co
Yep, that “is when off” looked strange. Not even sure what that is.
