Here you go:
* Dual Relay Adapter (i.e. Enerwave ZWN-RSM2 Adapter, Monoprice Dual Relay, Philio PAN04) Modified for MCO Dual Button Switch
* Copyright 2014 Joel Tamkin updated Morfsta 2016
* 2015-10-29: erocm123 - I removed the scheduled refreshes for my Philio PAN04 as it supports instant
* status updates with my custom device type
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
definition(
name: "MCO-S312-EU Dual Switch",
namespace: "morfsta",
author: "Morfsta",
description: "Associates Dual Relay MCO Switch Modules with one or two standard SmartThings 'switch' devices for compatibility with standard control and automation techniques",
category: "My Apps",
iconUrl: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience.png",
iconX2Url: "https://s3.amazonaws.com/smartapp-icons/Convenience/Cat-Convenience@2x.png")
preferences {
section("MCO Switch:") {
input "rsm", "capability.zwMultichannel", title: "Which MCO Switch?", multiple: false, required: true
input "switch1", "capability.switch", title: "First Switch?", multiple: false, required: true
input "switch2", "capability.switch", title: "Second Switch?", multiple: false, required: false
def installed() {
log.debug "Installed!"
//subscribe(rsm, "switch", rsmHandler)
subscribe(rsm, "switch1", rsmHandler)
subscribe(rsm, "switch2", rsmHandler)
subscribe(switch1, "switch", switchHandler)
subscribe(switch2, "switch", switchHandler)
initialize()
def updated() {
log.debug "Updated!"
unsubscribe()
initialize()
def switchHandler(evt) {
//log.debug "switchHandler: ${evt.value}, ${evt.deviceId}, ${evt.source}, ${switch2.id}"
switch (evt.deviceId) {
case switch1.id:
switch (evt.value) {
case 'on':
log.debug "switch 1 on"
rsm.on1()
break
case 'off':
log.debug "switch 1 off"
rsm.off1()
break
break
case switch2.id:
case 'on':
log.debug "switch 2 on"
rsm.on2()
break
case 'off':
log.debug "switch 2 off"
rsm.off2()
break
break
default:
pass
def rsmHandler(evt) {
log.debug "$evt.name $evt.value"
if (evt.name == "switch1") {
case 'on':
switch1.on()
break
case 'off':
switch1.off()
break
else if (evt.name == "switch2") {
case 'on':
switch2.on()
break
case 'off':
switch2.off()
break
def rsmRefresh() {
rsm.refresh()
def initialize() {
unschedule()
//def exp = "* * * * * ?"
//log.debug "Scheduling RSM refreshes"
//schedule(exp, rsmRefresh)
// TODO: subscribe to attributes, devices, locations, etc.
