How to manual remove and re-add Ecolink Motion
Is there a way to manually remove the EcoLink z-wave motion from ST? I got my new batch in the mail. When I add them by brand, it came across as just a z-wave device, not motion. I try to update the device handler using ST IDE to match up the other one I have, it didn’t work. So I want to go back to reset this
  1. Should I just delete the device from the ST IDE? Or can I do an exclusion like a light switch? If so, what button do I push to do exclusion as this is not a switch
  2. How do I add it back into ST after it is deleted? Do I reset the batteries / power cycle or is there a button or jumper I push or use?
https://support.smartthings.com/hc/en-us/articles/202294400-Ecolink-PIR-Motion-Detector-PIRZWAVE2-ECO- and http://manuals-backend.z-wave.info/make.php?lang=en&sku=PIRZWAVE2.5-ECO&cert=ZC10-16020001
