Hi,
Does anyone know how to pair on HomeMate App with orvibo touch classic wifi wall switch via the ZigBee mini hub connected to my wifi.
I had it removed from my homemate app with two switches but when I followed the instructions ie. press four times and fifth time Long pressed till it flickers fast, then click once more and a steady slow blinking light will be shown. I tried this multiple times but it still doesn’t connect but at “Adding device” mode then eventually failed as it complain the switch not in configuration mode in which I already did do. I tried to reduce my devices but still no luck.
Anyone can please kindly advise if you guys encounter this before.
Thanks in advance.
Rgds,
Ben
