How to install Smartthings Edge Drivers?
Hi @Mariano_Colmenarejo : Thanks for the reply. The issue I have is cannot even change the driver. The way the device is shown in my ST app does not leave me any options to change increments,… Therefore I suspect that the wrong driver is used. When checking in the ST HUB device I can see that the Driver “Z-Wave Sensor an Child Thermostat Mc” is installed on the hub but it does not seem to be used by my thermostats (Danfoss LC13). I found out that there is an issue with the latest ST app release to change drivers and followd up in this thread to figure out whether this is still an issue or its just me…
Hi @cartelcar
Your device will not pair with the driver because your fingerprints are not in the driver
Your device is a thermostat and this controller does not pair with real thermostats.
This driver pairs with motion sensors, contact sensors, …, that have temperature capability, that are included in the zwave sensor stock driver and allows you to create an individual virtual thermostat for that sensor.
these are the supported fingerprints
You can unenrol from the channel, but that’s rather a blunt instrument.
