Hi, @Bobby! I will check if an OTA firmware update is possible as you described with the engineering team. I’ll let you know their feedback
Update:
To make an OTA firmware update for direct-connected devices, you need to own a server for this purpose because the firmwareUpdate capability is only used to provide the firmware information, which means the update cannot be done through the SmartThings platform.
ESP-IDF >= 4.3 is compatible with Apple Silicon but smartthings SDK is reliant on an older version (3.3). ESP32 builds for a direct connected device are not possible using the excellent instructions on GitHub or in the forum. You can build on Raspberry so it’s not a question about ARM or Intel. I would really appreciate instructions/info on how to use the Smartthings SDK (for ESP32) with the latest ESP-IDF. The script-magic that happens with setup.py and build.py should be possible to bypass with a correct, possibly nitpicky, setup of an ESP-IDF project for the ESP32.
Serial numbers containing dashes (-) cannot be entered on an Android phone, e.g. STDKxxxx-beta-01. They can, however, be registered in the web interface.
Currently my onboarding config states that a QR code should be used BUT… the user must enter a serial number anyway. At least on an Android phone.
Old (test) onboarding configs, i.e. names, are visible in the app as testing device types although they have been deleted from the developer workspace. AFAIK there is no CLI command to list onboarding configs.
I would really like to be able to call someone about the development issues I have. The company I work for, as a consultant, is planning to launch a product (direct connected device) this spring and they would not hesitate to pay for support.
I can’t promise it will be any better than responses you get here, and they may just direct you back to this forum, but Samsung does have a separate channel for partner developers.
Start here:
Follow all the links to “developers“ and eventually you will get here:
And ultimately you will get to the page where you can enroll as a partner. They say you will get quick technical responses there, but I have no idea what the reality is. But in your situation it might be worth a try.
If this is the case, why is the command “updateFirmware” in the capabilities reference document? What would that command actually do if the SmartThings platform is only providing firmware information? Is there any more documentation showing how this flow is expected to work?
Not so far, sorry. The team is continuously working on improving the documentation, I’ll report this to get feedback about the capability function. I’ll let you know in case I receive more info.
I asked the internal team and they mentioned there’s no docker image for this purpose. The development environment depends on which chipset each developer uses so, that’s why it is not provided.
Hello, I have been following the instruction and was able to compile and flash the firmware onto ESP32, as well as set up device profile for the switch example. The problem happens when I try to add device in my ST app. The error is "This device isn't supported in your Samsung account's country or region. (Error code: 07-008)". On Product Info section in Developer Workspace, I set the availability to be United States. I checked my account’s country of region and it is also US. Any idea on what the error can be? Thanks!
AlejandroPadilla
(Please contact @nayelyz or @Luis_Humberto_Medina )
102
Hi @jackj
I will send you a message asking for some information, and I will continue to support you there.
I successfully developed a few esp8266 direct connect devices. For my next device, I need to control a servo and I am struggling. If you could share an example or an helpful link, I would appreciate.
Currently my workaround is annoying because it requires 2 boards:
Board 1: ino project to control the servo using an api I expose
Board 2: SmartThings direct connect device that calls the Board 1 api
Hello everyone, this is just a bit update about the Add device (Onboarding Process)
because the steps regarding “My Testing Devices” in this tutorial are outdated and we received some questions about it.
Currently, when you go to “add device” in the app, you get two options at the top, in this case, you need to select “partner devices”.
Then, you’ll see “My testing devices” at the top section called “Recommendations” on that page.
I had the same issue please can u help me ,
I had error 07-008 in the smartthings app when i want to add my device ( my region is tunisia and my device availability is tunisia also )
AlejandroPadilla
106
Now I’m trying to encrypt s/n and paired keys into a BIN to flash it in STNV partition. Then I flash the keys (used to encypt this BIN) to the nvs_key partition.
I can’t get “switch_example” to work by performing the encryption process that way. Should I modify source code to init nvs as secure mode or make some other modifications?
Is there any guide or tutorial to help me with those steps?
I asked the engineering team about this and they let us know the following:
In the open source example and getting started documentation, the “device identity” (combination of serial number , ed25519 keypair) is added to the Application firmware.
The configuration described on #1 is for a quick PoC but it can’t be reused for mass production (building individual firmware for each device isn’t generally acceptable)
So, you need to update your implementation when considering production by putting the “device identity” into a dedicated partition called STNV (SmartThings Non-Volatile).
Using the STNV partition, the SDK would access the “device identity” not from the firmware built-in “onboarding_config.json” but from STNV which would be injected separately.
To do this, the SDK configuration needs to be changed to enable “CONFIG_STDK_IOT_CORE_SUPPOORT_STNV_PARTITION” option, for example here: st-device-sdk-c-ref/apps/esp32/switch_example/sdkconfig at develop · SmartThingsCommunity/st-device-sdk-c-ref · GitHub
