How to actually USE the Schlage RS100hc?
After seeing them listed as supported on https://smartthings.zendesk.com/entries/23391791-What-Can-I-Do-with-a-Schlage-Nexia-RS100HC-V-N-N-SL-Home-Door-and-Window-Sensor- , I purchased 4 sensors.
I was able to add them to the ST env fine, but they do not generate Open/Close events, the icon never changes. Smartapps can be configured to use them as sensors, but of course they never fire.
In the graph Console view, when I open/close them, it generates the following error message instead of changing state:
29a5e910-3396-48b4-bea9-8fae8f9dd7a4 8:21:24 AM: debug Parse returned []
29a5e910-3396-48b4-bea9-8fae8f9dd7a4 8:21:24 AM: warn Exception ‘org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object ‘null’ with class ‘null’ to class ‘byte’. Try ‘java.lang.Byte’ instead’ encountered parsing 'cmd: 3003, payload: FF’
29a5e910-3396-48b4-bea9-8fae8f9dd7a4 8:21:22 AM: debug Parse returned []
29a5e910-3396-48b4-bea9-8fae8f9dd7a4 8:21:22 AM: warn Exception ‘org.codehaus.groovy.runtime.typehandling.GroovyCastException: Cannot cast object ‘null’ with class ‘null’ to class ‘byte’. Try ‘java.lang.Byte’ instead’ encountered parsing ‘cmd: 3003, payload: 00’
@idean
These are probably one of my favorite devices. The only issue is that Smart Things doesn’t register them correctly when pairing. It is an easy fix:
Log into ide.smarthings.com (it should be your normal email and password)
Go to devices
Click on the device
Scroll all the way down to bottom and click “edit"
Find the “device type” drop down box
Scroll to and select 'Schlage Contact Sensor"
Scroll to the bottom and click 'Update”
Repeat for the other sensors and you should be good to go.
Yes! Thank you, that did it!
