How Do I Reinstall My IRIS Keypad?
My IRIS keypad isn’t showing in my app. How do I reinstall it?
You’ll need this:
How do I actually get install started what do I do on the device?
You’re going to need to get the driver from https://rboyapps.com/ which means purchasing a license.
Rboy’s site and the post above provide instructions and help.
Have you installed edge drivers before? If not i believe that same post also has links to how to do that.
I’m traveling and mobile at the moment so I can’t easily find more info for you right now.
Thanks, I have it installed but can’t find where to change the temp to F from C
Hi @joelw135, the instructions for adding codes are in materials mentioned above. You will need Smart Lock Guest Access installed via the Life section.
Changing to degree scale I believe is in settings, I think.
Thank you for the guidance. The temperature changed on it’s own, as I guess it is in the Smartthings settings.
