I’d like to use it in my humidor, and setup a notification if humidity goes out of range. Is it accurate within 1-2%?
Hey Cory,
We don’t make a humidity sensor, but you could find other ZigBee HA or Z-Wave sensors and use those.
Oh, my bad. i thought the multi-sensor device had one.
I’ve been looking around for a humidity sensor, because I’d like to use one in conjunction with a smart outlet and a dehumidifer (in the basement) or humidifier (in a bedroom). Alas, I haven’t been able to find one already in production. There are moisture sensors, but those appear to be designed to detect leaks or floods, not to give specific humidity levels.
I use the SmartSense Temp/Humidity Sensor in conjunction with the Smart Power outlet to control my dehumidifier.
