I’ve purchased a Secure SSR-320 boiler switch/actuator and the device handler i grabbed from here (name thanks Lime Ninja)
The issue i am having is, i can control the HW and CH separately from the app but i want to set up some kind of schedule for each channel - now when accessed from any other smart app the device handler only shows up as a single switch which is labelled as Heating, the main and central switch on the app, this doesn’t control the HW and CH separately.
Is there a way of setting a up a virtual switch or another app that will recognise the HW and CH switched within the handler?
I have attached a pic for (hopefully) Clarity as I’m not always the best at explaining things.
I had the same issue. Trust me it’s worth having a look. Documentation is good, simple to install and it’s intuitive. What you’re looking to do above will probably take less than ten minutes.
OK, I’ve opened CoRE and the problem is still the same - The device handler, when open has two switches i need to control but when its accessed by another app its only recognised as a single switch, which is not actually related, as far as i can tell, to what i need it to do. See below it shows as Pro test 1 and this only operates a single switch when open is clearly two switches (3 actually).
