Honeywell Smart Wi-Fi Thermostat Compatibility
Hi Jody…is there a way to send a permanent hold to my rth6580wf?
I would like to create a “vacation” or “away for a long time” tile, which keeps the temperature I desire until I return. Then I want it to go back to its normal schedule.
I want to automate my usual process of:
  • go to the Total Comfort website and sign in
  • manually adjust the temp to something really high (80F) or low (55F) depending on season.
  • Select “Switch to Permanent Hold”
  • Press Submit.
BTW: I saw Brad Goodman’s website and it states that if you dot send anything to the “NextPeriod” parameter it will be permanent. Your code sends “null” which theoretically should work, but it just does the hold until next period.
Am I missing something?
Thanks a lot to you and ethomasii for the work that you did.
