I went in to HomeDepot to check to see if the Wink hub has dropped yet to the next lower value from the $39 price and at least for my store it has not yet BUT it was worth the stop over because I picked up this Hue Color bulb for $18
I called the other Home Depot and they didn’t have anything.
1st spot to check is the normal shelf space for yellow tags. Then they get moved to clearance areas with progressively bigger discounts.
Usually on end caps. or table/rack in isle 1 by electrical/ paint. 1 by bathroom/ loading dock and a 3rd of in a dark corner by bathroom supplies ( Toilets , tubs ) or building supplies ( Doors & Windows, the DIY, not the installed by HD contractor )
