Cortex
September 20, 2018, 3:48am
1
Hi everyone,
I recently flashed a Sonoff with Tasmota. I am currently wondering how to see the Sonoff inside SmartThings from Home Assistant. I want to be able to turn off everything when my arrival sensor leaves. However, I don’t know how to see the switches in ST.
Ryan780
September 21, 2018, 11:46pm
2
There is a way to use Tasmota with ST but I never got it to work. I used this firmware for my sonoff basics:
[image]
2017_10_04 Update: If the flashing method in this first post does not work for your device, try the method mentioned in this post:
2017_05_10 Update: Sonoff Dual - Firmware and device handler and child device handler . Flashing info here . Sonoff 4CH - Firmware and device handler and child device handler .
2017_01_21 Update: Release of firmware and SmartApp updates for the Sonoff Touch and Sonoff S20 . Picture for flashing Sonoff Touch in this post .
2016_10_14 Update: I have been playing with the Sonoff TH (16 Amp Version) and am finished with a SmartThings capable firmware for it. This device has a 10 & 16 Amp version and support for a temperature sensor attachment. The device handler supports both temperature and humidity. Here is the firmware & here is the device handler . You …
