Hi everyone,
Has anyone managed to get either the SonOff TH10 or TH16 to successfully work with smartthings?
i have flashed both devices with the latest version of the tasmota firmware and they are up and running as expected on my home wifi with tasmota.
I have then installed @Eric Maycock (@erocm123) two device handlers Sonoff TH - Tasmota and Sonoff TH Wifi Switch (excellent work Eric!) - unfortunately neither will switch the relay from the smartthings app. (i am using the new smartthings app not smartthings classic). Just getting this bit to work would be a start.
With regards to reading temperature and humidity i am using both the AM230 and DS18B20 sensor and whilst i can see readings in tasmota i get nothing on the app using either of the device handlers above. i read some old post about temp and humidity not yet being supported however i see in the Sonoff TH Wifi Switch device handler that both temp and humidity are being parsed.
if anyone has had success with these i would be grateful of a steer in the right direction.
thanks for you help
Rob
