Nice thank you for taking a look at it. I have a device i would love you to take a look at for me now.
This is code form https://github.com/jwsf/device-type.ted5000/blob/master/device-type.ted5000.groovy and i made changes again so it works best for me. Here is what it looks like on my phone. I want to make the read outs different and cant figure out how and where to put my conversions. the 83 USD should really read $0.83 USD the 7614 USD should read $76.14 USD (this if the month to date) and the 1170 V to read 117.0 volts. So really i just need to know where and how to put the / 100 for the USD and the / 10 for the volts.
preferences {
input("url", "text", title: "URL", description: "The URL (including port number) of your TED5000 device (must be available to the public internet - example http://12.34.56.78:4444)", required: true)
input("usr", "email", title: "Username", description: "The username configured in Network Settings on your TED5000", required: true)
input("pass", "password", title: "Password", description: "The password configured in Network Settings on your TED5000", required: true)
input(type: "enum", name: "chartGranularity", title: "Chart Granularity", options: granularityOptions(), defaultValue: "Daily", style: "segmented")
metadata {
// Automatically generated. Make future change here.
definition (name: "TED-5000", author: "tom") {
capability "Energy Meter"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Power Meter"
// simulator metadata
simulator {
for (int i = 100; i <= 3000; i += 200) {
status "power ${i} W": new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: i, precision: 3, meterType: 4, scale: 2, size: 4).incomingMessage()
for (int i = 0; i <= 100; i += 10) {
status "energy ${i} kWh": new physicalgraph.zwave.Zwave().meterV1.meterReport(
scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
// UI tile definitions
tiles {
valueTile( "power", "device.power", canChangeBackground:true
{state( "power",
label:'${currentValue} W',
backgroundColors:[
[value: 1, color: "#153591"],
[value: 500, color: "#1e9cbb"],
[value: 1000, color: "#90d2a7"],
[value: 2500, color: "#44b621"],
[value: 4000, color: "#f1d801"],
[value: 6000, color: "#d04e00"],
[value: 8000, color: "#bc2323"]
valueTile( "volts",
"device.volts", decoration: "flat"
state("volts",
label:'${currentValue} V'
valueTile( "cost",
"device.cost", decoration: "flat"
state("cost",
label:'${currentValue} USD'
valueTile( "costmtd",
"device.costmtd", decoration: "flat"
state("costmtd",
standardTile("refresh", "device.power") {
state "default", action:"refresh.refresh", icon:"st.secondary.refresh"
main(["power", "cost", "volts"])
details(["power", "cost", "costmtd", "volts", "refresh"])
def poll() {
doUpdate()
def refresh() {
doUpdate()
def doUpdate() {
// Build auth string
def auth = settings.usr + ":" + settings.pass
auth = auth.getBytes()
auth = auth.encodeBase64()
String authString = auth
// Build URL
def URL = settings.url + "/api/LiveData.xml"
log.debug "Connecting to " + URL
def params = [
uri: URL,
headers: [
'Authorization': "Basic ${authString}"
// This closure is called to parse the XML if it is successfully retrieved
def successClosure = { response ->
log.debug "Request to TED5000 was successful"
def power = response.data.Power.Total.PowerNow
def volts = response.data.Voltage.Total.VoltageNow
def cost = response.data.Cost.Total.CostNow
def costmtd = response.data.Cost.Total.CostMTD
log.debug "Sending event - power: $power W Volts: $voltageNow V Cost: $costNow and CostMTD: $costMTD"
sendEvent (name: "cost", value: cost, unit:"USD")
sendEvent (name: "volts", value: volts, unit:"V")
sendEvent (name: "power", value: power, unit:"W")
sendEvent (name: "costmtd", value: costmtd, unit:"USD")
try {
// Get the XML from the TED5000
httpGet(params, successClosure)
} catch ( java.net.UnknownHostException e) {
log.error "Unknown host - check the URL and PORT for your device"
sendEvent name: "power", value: "Unknown host"
} catch (java.net.NoRouteToHostException t) {
log.error "No route to host - check the URL and PORT for your device " + URL
sendEvent name: "power", value: "No route to host"
} catch (java.io.FileNotFoundException fnf) {
log.error "File not found - check the URL and PORT for your device " + URL
sendEvent name: "power", value: "XML not found"
} catch (java.io.IOException e) {
log.error "Authentication error - check USERNAME and PASSWORD. This can also occur if the TED5000 cannot be reached"
sendEvent name: "power", value: "Auth error"
} catch (any) {
log.error "General error trying to connect to TED and retrieve data " URL
sendEvent name: "power", value: "ERROR"
def getVisualizationData(attribute) {
log.debug "getChartData for $attribute"
def keyBase = "measure.${attribute}${getGranularity()}"
log.debug "getChartData state = $state"
def dateBuckets = state[keyBase]
//convert to the right format
def results = dateBuckets?.sort { it.key }.collect {
date: Date.parse("yyyy-MM-dd", it.key),
average: it.value.average,
min: it.value.min,
max: it.value.max
log.debug "getChartData results = $results"
results
private storeData(attribute, value, dateString = getKeyFromDateDaily()) {
log.debug "storeData initial state: $state"
def keyBase = "measure.${attribute}"
def numberValue = value.toBigDecimal()
// create bucket if it doesn't exist
if (!state[keyBase]) {
state[keyBase] = [:]
log.debug "storeData - attribute not found. New state: $state"
if (!state[keyBase][dateString]) {
//no date bucket yet, fill with initial values
state[keyBase][dateString] = [:]
state[keyBase][dateString].average = numberValue
state[keyBase][dateString].runningSum = numberValue
state[keyBase][dateString].runningCount = 1
state[keyBase][dateString].min = numberValue
state[keyBase][dateString].max = numberValue
log.debug "storeData date bucket not found. New state: $state"
// remove old buckets
def old = getKeyFromDateDaily(new Date() - 10)
state[keyBase].findAll { it.key < old }.collect { it.key }.each { state[keyBase].remove(it) }
} else {
//re-calculate average/min/max for this bucket
state[keyBase][dateString].runningSum = (state[keyBase][dateString].runningSum.toBigDecimal()) + numberValue
state[keyBase][dateString].runningCount = state[keyBase][dateString].runningCount.toInteger() + 1
state[keyBase][dateString].average = state[keyBase][dateString].runningSum.toBigDecimal() / state[keyBase][dateString].runningCount.toInteger()
log.debug "storeData after average calculations. New state: $state"
if (state[keyBase][dateString].min == null) {
} else if (numberValue < state[keyBase][dateString].min.toBigDecimal()) {
if (state[keyBase][dateString].max == null) {
} else if (numberValue > state[keyBase][dateString].max.toBigDecimal()) {
log.debug "storeData after min/max calculations. New state: $state"
// This next method is only used from the simulator
def result = null
def cmd = zwave.parse(description, [0x31: 1, 0x32: 1, 0x60: 3])
if (cmd) {
result = createEvent(zwaveEvent(cmd))
log.debug "Parse returned ${result?.descriptionText}"
return result
def zwaveEvent(physicalgraph.zwave.commands.meterv1.MeterReport cmd) {
if (cmd.scale == 0) {
[name: "energy", value: cmd.scaledMeterValue, unit: "kWh"]
} else if (cmd.scale == 1) {
[name: "energy", value: cmd.scaledMeterValue, unit: "kVAh"]
else {
[name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W"]
def getGranularity() {
chartGranularity ?: "Daily"
def granularityOptions() { ["Daily", "Hourly"] }
private getKeyFromDateDaily(date = new Date()) {
date.format("yyyy-MM-dd")
private getKeyFromDateHourly(date = new Date()) {
date.format("yyyy-MM-dd:HH")
