Hi guys,
I have to preface this post by saying that I’m pretty much a complete newbie when it comes to any sort of code, so please be gentle
That said, I am very interested in setting up a good device handler for the Qubino Flush Dimmer Plus as there doesn’t seem to be any community device handler for it yet. I have used the Fibaro Dimmer 2 device handler by Rajiv which is a brilliant handler for that device and allows access to all the advanced features.
As I am still waiting for the Qubino Dimmers (should arrive tomorrow) I have pulled the fingerprint from a post on the forum here, and have edited the code so that all the parameter option panes are set up as per the Qubino manual (found here http://qubino.com/download/1293/ )
Beyond that I have no clue what I’m doing really. I believe I have correctly set the byte size per parameter by altering the “size” setting under “def configureAfterSecure() {” on lines 458-479… I haven’t altered anything else.
Would greatly appreciate any advice as to what else might need to change in order to get this to work. Thanks for any input at all (and thanks to Rajiv for the fibaro dimmer 2 code).
* Copyright 2016 SmartThings
* Licensed under the Apache License, Version 2.0 (the "License"); you may not use this file except
* in compliance with the License. You may obtain a copy of the License at:
* http://www.apache.org/licenses/LICENSE-2.0
* Unless required by applicable law or agreed to in writing, software distributed under the License is distributed
* on an "AS IS" BASIS, WITHOUT WARRANTIES OR CONDITIONS OF ANY KIND, either express or implied. See the License
* for the specific language governing permissions and limitations under the License.
metadata {
definition (name: "Qubino Dimmer Plus", namespace: "smartthings", author: "Zeeflyboy") {
capability "Energy Meter"
capability "Actuator"
capability "Switch"
capability "Power Meter"
capability "Polling"
capability "Refresh"
capability "Sensor"
capability "Configuration"
capability "Switch Level"
//Extending devices with scene attribute
attribute "scene", "number"
command "reset"
command "changeSingleParamAfterSecure"
command "configureAfterSecure"
fingerprint deviceId: "0x1101", inClusters: "0x5E,0x86,0x72,0x5A,0x73,0x20,0x27,0x25,0x26,0x30,0x71,0x32,0x60,0x85,0x8E,0x59,0x70,0xEF,0x20"
// simulator metadata
simulator {
status "on": "command: 2003, payload: FF"
status "off": "command: 2003, payload: 00"
status "09%": "command: 2003, payload: 09"
status "10%": "command: 2003, payload: 0A"
status "33%": "command: 2003, payload: 21"
status "66%": "command: 2003, payload: 42"
status "99%": "command: 2003, payload: 63"
for (int i = 0; i <= 10000; i += 1000) {
status "power ${i} W": new physicalgraph.zwave.Zwave().meterV3.meterReport(
scaledMeterValue: i, precision: 3, meterType: 4, scale: 2, size: 4).incomingMessage()
for (int i = 0; i <= 100; i += 10) {
status "energy ${i} kWh": new physicalgraph.zwave.Zwave().meterV3.meterReport(
scaledMeterValue: i, precision: 3, meterType: 0, scale: 0, size: 4).incomingMessage()
["FF", "00", "09", "0A", "21", "42", "63"].each { val ->
reply "2001$val,delay 100,2602": "command: 2603, payload: $val"
// tile definitions
tiles(scale: 2) {
multiAttributeTile(name:"switch", type: "lighting", width: 6, height: 4, canChangeIcon: true){
tileAttribute ("device.switch", key: "PRIMARY_CONTROL") {
attributeState "on", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
attributeState "off", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
attributeState "turningOn", label:'${name}', action:"switch.off", icon:"st.switches.switch.on", backgroundColor:"#79b821", nextState:"turningOff"
attributeState "turningOff", label:'${name}', action:"switch.on", icon:"st.switches.switch.off", backgroundColor:"#ffffff", nextState:"turningOn"
tileAttribute ("device.level", key: "SLIDER_CONTROL") {
attributeState "level", action:"switch level.setLevel"
valueTile("power", "device.power", decoration: "flat", width: 2, height: 2) {
state "default", label:'${currentValue} W'
valueTile("energy", "device.energy", decoration: "flat", width: 2, height: 2) {
state "default", label:'${currentValue} kWh'
standardTile("reset", "device.energy", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:'reset kWh', action:"reset"
standardTile("configureAfterSecure", "device.configure", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "configure", label:'', action:"configureAfterSecure", icon:"st.secondary.configure"
standardTile("refresh", "device.power", inactiveLabel: false, decoration: "flat", width: 2, height: 2) {
state "default", label:'', action:"refresh.refresh", icon:"st.secondary.refresh"
main(["switch","power","energy"])
details(["switch","power","energy","configureAfterSecure","refresh","reset"])
preferences {
def paragraph = "GROUP 0 - The Dimmer behavior - Basic functionalities"
input name: "param1", type: "number", range: "0..1", defaultValue: "0", required: true,
title: paragraph + "\n\n" +
"1. Input 1 Switch Type. " +
"Defines the type of switch. " +
"0 - Mono-stable push type switch.\n" +
"1 - Bi-stable toggle type switch.\n" +
"Default value: 0."
input name: "param2", type: "number", range: "0..1", defaultValue: "0", required: true,
title: "2. Input 2 Switch Type. " +
"Default value: 0."
input name: "param3", type: "number", range: "0..1", defaultValue: "0", required: true,
title: "3. Input 2 Contact Type. " +
"Defines the contact type for Input 2. " +
"0 - NO normally open input type.\n" +
"1 - NC normally closed input type.\n" +
"Default value: 0."
input name: "param4", type: "number", range: "0..1", defaultValue: "0", required: true,
title: "3. Input 3 Contact Type. " +
"Defines the contact type for Input 3. " +
"Default value: 0."
input name: "param10", type: "enum", defaultValue: "255", required: true,
options: ["0" : "0",
"1" : "1",
"2" : "2",
"255" : "255"],
title: "10. ALL ON/ALL OFF function. " +
"Allows for activation/deactivation of Z-Wave commands enabling/disabling all devices located in direct range of the main controller.\n" +
"Available settings:\n" +
"0 = All ON not active, All OFF not active,\n" +
"1 = All ON not active, All OFF active,\n" +
"2 = All ON active, All OFF not active,\n" +
"255 = All ON active, All OFF active.\n" +
"Default value: 255."
input name: "param11", type: "number", range: "1..32536", defaultValue: "0", required: true,
title: "11. Automatic turning off output after set time. " +
"Defines the time in seconds before auto off.\n" +
"Available settings: 1-32536 (step is 1 second, 0 is disabled).\n" +
"Default value: 0."
input name: "param12", type: "number", range: "1..32535", defaultValue: "0", required: true,
title: "6. Automatic turning on output after set time. " +
"Defines the time in seconds before auto on.\n" +
"Available settings: 1-32535 (step is 1 second, 0 is disabled).\n" +
"Default value: 0."
input name: "param20", type: "number", range: "0..1", defaultValue: "0", required: true,
title: "20. Enable/Disable 3 way switch. " +
"Dimming is done by push button to L1 by default, 3way switch dimming can be controlled by push button connected to L1 and L2.\n" +
"0 - Single push button (connected to L1).\n" +
"1 - 3 way switch (connected to L1 and L2).\n" +
"Default value: 0."
input name: "param21", type: "number", range: "0..1", defaultValue: "0", required: true,
title: "21. Enable/Disable Double click function. " +
"If enabled, a fast double click will set dimming at maximum power.\n" +
"0 - Double Click disabled.\n" +
"1 - Double Click enabled.\n" +
"Default value: 0."
input name: "param30", type: "number", range: "0..1", defaultValue: "0", required: true,
title: "30. State of the device after a power failure. " +
"Defines whether the Dimmer will return to the last state before power failure.\n" +
"0 = Dimmer restores its state before power failure.\n" +
"1 = Dimmer does not save the state before a power failure, it returns to „off” position,\n" +
"Default value: 0."
input name: "param40", type: "number", range: "0..100", defaultValue: "5", required: true,
title: "40. Power Reporting in Watts on power change. " +
"Power report is sent only when actual Power in Watts in real time changes by more than set percentage. " +
"If power change is less than 1W, report is not sent regardless of percentage set.\n" +
"0 - Reporting disabled.\n" +
"1-100 - 1% to 100% reporting enabled.\n"
"Default value: 5."
input name: "param42", type: "number", range: "0..32767", defaultValue: "0", required: true,
title: "42. Power Reporting in Watts by time interval. " +
"Power report is sent with time interval set by entered value (in seconds). " +
"0 = Disabled.\n" +
"1-32767 - time interval in seconds.\n" +
"Default value: 0."
input name: "param60", type: "number", range: "0..98", defaultValue: "1", required: true,
title: "60. Minimum Dimming Value. " +
"Defines the minimum Dimming power level as a percentage.\n" +
"1-98 - Minimum dimming percentage is set by entered value.\n" +
"Default value: 1."
input name: "param61", type: "number", range: "2..99", defaultValue: "99", required: true,
title: "61. Maximum Dimming Value. " +
"Defines the Maximum Dimming power level as a percentage.\n" +
"2-99 - Maximum dimming percentage is set by entered value.\n" +
"Default value: 99."
input name: "param65", type: "number", range: "50..255", defaultValue: "100", required: true,
title: "65. Dimming time (soft on/off). " +
"Set value determines time between min and max dimming values by short press of button or through UI.\n" +
"50-255 - 500ms to 2550ms, step is 10ms.\n" +
"Default value: 100."
input name: "param66", type: "number", range: "1..255", defaultValue: "3", required: true,
title: "66. Dimming time while key is held. " +
"Set value determines time between min and max dimming values by continuous hold of push button L1 or associated device.\n" +
"1-255 - 1s to 255s, step is 1s.\n" +
"Default value: 3."
input name: "param67", type: "number", range: "0..1", defaultValue: "0", required: true,
title: "67. Ignore start level. " +
"This parameter is used with association group 3.\n" +
"0 = Respect start level\n" +
"1 = Ignore start level.\n" +
"Default value: 0."
input name: "param68", type: "number", range: "1..127", defaultValue: "0", required: true,
title: "68. Dimming duration. " +
"This parameter is used with association group 3, the duration field MUST specify the time that the transition should take.\n" +
"0 - Dimming duration according to parameter 66.\n" +
"1-127 - Dimming duration in seconds.\n"
"Default value: 0."
input name: "param100", type: "enum", defaultValue: "0", required: true,
"1" : "1",
"2" : "2",
"3" : "3",
"4" : "4",
"5" : "5",
"6" : "6",
"9" : "9"],
title: "100. Enable/Disable endpoints L2 or select notification type and event.\n" +
"Note1: After parameter Change, first exclude module (without setting parameters to default) then wait at least 30s to re-include.\n" +
"Note2: When the parameter is set to 9, the notifications are sent for home security.\n" +
"0 = Endpoint L2 disabled\n" +
"1 = Home security, motion detection, unknown loc.\n" +
"2 = CO, Carbon Monoxide detected, unknown loc.\n" +
"3 = CO2, Carbon Dioxide detected, unknown loc.\n" +
"4 = Water Alarm, Water leak detected, unknown loc.\n" +
"5 = Heat Alarm, Overheat detected, unknown loc.\n" +
"6 = Smoke Alarm, Smoke detected, unknown loc.\n" +
"9 = Sensor binary.\n" +
"Default value: 0."
input name: "param101", type: "enum", defaultValue: "0", required: true,
"1" : "1",
"2" : "2",
"3" : "3",
"4" : "4",
"5" : "5",
"6" : "6",
"9" : "9"],
title: "101. Enable/Disable endpoints L3 or select notification type and event.\n" +
"0 = Endpoint L3 disabled\n" +
"Default value: 0."
input name: "param110", type: "number", range: "0..32536", defaultValue: "32536", required: true,
title: "110. Temperature sensor offset settings. " +
"Set value is added or subtracted to actual measured value by sensor.\n" +
"32536 = offset is 0.0C.\n" +
"1-100 = Value from 0.1C to 10.0C is added to actual measured temperature.\n" +
"1001-1100 = Value from -0.1C to -10.0C is subtracted from actual measured temperature.\n" +
"Default value: 0."
input name: "param120", type: "number", range: "0..127", defaultValue: "5", required: true,
title: "120. Temperature sensor reporting.\n" +
"If digital temperature sensor is connected, module reports measured temperature on temperature change defined by this parameter.\n" +
"0 = Reporting disabled\n" +
"1-127 = 0.1C to 12.7C, step is 0.1C.\n" +
"Default value: 5."
log.trace(description)
log.debug("RAW command: $description")
def result = null
if (description != "updated") {
def cmd = zwave.parse(description.replace("98C1", "9881"), [0x20: 1, 0x26: 3, 0x32: 3, 0x25: 1, 0x98: 1, 0x70: 1, 0x85: 2, 0x9B: 1, 0x90: 1, 0x73: 1, 0x30: 1, 0x28: 1, 0x72: 1])
if (cmd) {
result = zwaveEvent(cmd)
log.debug "Parsed '${description}' to ${result.inspect()}"
return result
def zwaveEvent(physicalgraph.zwave.commands.sceneactivationv1.SceneActivationSet cmd) {
log.debug( "Scene ID: $cmd.sceneId")
log.debug( "Dimming Duration: $cmd.dimmingDuration")
sendEvent(name: "scene", value: "$cmd.sceneId", data: [switchType: "$settings.param20"], descriptionText: "Scene id $cmd.sceneId was activated", isStateChange: true)
log.debug( "Scene id $cmd.sceneId was activated" )
// Devices that support the Security command class can send messages in an encrypted form;
// they arrive wrapped in a SecurityMessageEncapsulation command and must be unencapsulated
def zwaveEvent(physicalgraph.zwave.commands.securityv1.SecurityMessageEncapsulation cmd) {
log.trace(cmd)
def encapsulatedCommand = cmd.encapsulatedCommand([0x20: 1, 0x26: 3, 0x32: 3, 0x25: 1, 0x98: 1, 0x70: 1, 0x85: 2, 0x9B: 1, 0x90: 1, 0x73: 1, 0x30: 1, 0x28: 1, 0x72: 1]) // can specify command class versions here like in zwave.parse
if (encapsulatedCommand) {
return zwaveEvent(encapsulatedCommand)
} else {
log.warn "Unable to extract encapsulated cmd from $cmd"
createEvent(descriptionText: cmd.toString())
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicReport cmd) {
log.trace(cmd)
dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.basicv1.BasicSet cmd) {
log.trace(cmd)
//dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchmultilevelv3.SwitchMultilevelReport cmd) {
log.trace(cmd)
dimmerEvents(cmd)
def zwaveEvent(physicalgraph.zwave.commands.switchbinaryv1.SwitchBinaryReport cmd)
log.trace(cmd)
dimmerEvents(cmd)
def dimmerEvents(physicalgraph.zwave.Command cmd) {
log.trace(cmd)
def result = []
def value = (cmd.value ? "on" : "off")
def switchEvent = createEvent(name: "switch", value: value, descriptionText: "$device.displayName was turned $value")
result << switchEvent
if (cmd.value) {
result << createEvent(name: "level", value: cmd.value, unit: "%")
if (switchEvent.isStateChange) {
result << response(["delay 3000", zwave.meterV2.meterGet(scale: 2).format()])
return result
def zwaveEvent(physicalgraph.zwave.commands.meterv3.MeterReport cmd) {
log.trace(cmd)
if (cmd.meterType == 1) {
if (cmd.scale == 0) {
return createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kWh")
} else if (cmd.scale == 1) {
return createEvent(name: "energy", value: cmd.scaledMeterValue, unit: "kVAh")
} else if (cmd.scale == 2) {
return createEvent(name: "power", value: Math.round(cmd.scaledMeterValue), unit: "W")
} else {
return createEvent(name: "electric", value: cmd.scaledMeterValue, unit: ["pulses", "V", "A", "R/Z", ""][cmd.scale - 3])
log.trace(cmd)
log.debug "No handler for $cmd"
// Handles all Z-Wave commands we aren't interested in
createEvent(descriptionText: cmd.toString(), isStateChange: false)
def on() {
log.trace("on")
secureSequence([
zwave.basicV1.basicSet(value: 0xFF),
zwave.switchMultilevelV1.switchMultilevelGet()
def off() {
log.trace("off")
secureSequence([
zwave.basicV1.basicSet(value: 0x00),
def poll() {
log.trace("poll")
secureSequence([
zwave.meterV2.meterGet(scale: 0),
def refresh() {
log.trace("trace")
secureSequence([
def reset() {
log.trace("reset")
return secureSequence([
zwave.switchMultilevelV1.switchMultilevelGet(),
zwave.meterV2.meterReset(),
def setLevel(level) {
log.trace("setlevel")
if(level > 99) level = 99
secureSequence([
zwave.basicV1.basicSet(value: level),
], 5000)
def changeSingleParamAfterSecure(paramNum, paramSize, paramValue) {
log.debug "changeSingleParamAfterSecure(paramNum: $paramNum, paramSize: $paramSize, paramValue: $paramValue)"
def cmds = secureSequence([
zwave.configurationV1.configurationSet(parameterNumber: paramNum, size: paramSize, scaledConfigurationValue: paramValue)
cmds
log.debug "configureAfterSecure()"
zwave.configurationV1.configurationSet(parameterNumber: 1, size: 1, scaledConfigurationValue: param1.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 2, size: 1, scaledConfigurationValue: param2.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 3, size: 1, scaledConfigurationValue: param3.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 4, size: 1, scaledConfigurationValue: param4.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 10, size: 2, scaledConfigurationValue: param5.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 11, size: 2, scaledConfigurationValue: param6.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 12, size: 2, scaledConfigurationValue: param7.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 20, size: 1, scaledConfigurationValue: param8.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 21, size: 1, scaledConfigurationValue: param9.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 30, size: 1, scaledConfigurationValue: param10.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 40, size: 1, scaledConfigurationValue: param11.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 42, size: 2, scaledConfigurationValue: param13.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 60, size: 1, scaledConfigurationValue: param15.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 61, size: 1, scaledConfigurationValue: param16.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 65, size: 2, scaledConfigurationValue: param19.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 66, size: 2, scaledConfigurationValue: param20.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 67, size: 1, scaledConfigurationValue: param21.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 68, size: 1, scaledConfigurationValue: param22.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 100, size: 1, scaledConfigurationValue: param23.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 101, size: 1, scaledConfigurationValue: param24.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 110, size: 2, scaledConfigurationValue: param25.toInteger()),
zwave.configurationV1.configurationSet(parameterNumber: 120, size: 1, scaledConfigurationValue: param26.toInteger()),
// Register for Group 1
if(paramAssociationGroup1) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:1, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:1, nodeId: [zwaveHubNodeId]))
// Register for Group 2
if(paramAssociationGroup2) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:2, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:2, nodeId: [zwaveHubNodeId]))
// Register for Group 3
if(paramAssociationGroup3) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:3, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:3, nodeId: [zwaveHubNodeId]))
// Register for Group 4
if(paramAssociationGroup4) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:4, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:4, nodeId: [zwaveHubNodeId]))
// Register for Group 5
if(paramAssociationGroups5) {
cmds << secure(zwave.associationV2.associationSet(groupingIdentifier:5, nodeId: [zwaveHubNodeId]))
else {
cmds << secure(zwave.associationV2.associationRemove(groupingIdentifier:5, nodeId: [zwaveHubNodeId]))
cmds
def configure() {
// Wait until after the secure exchange for this
log.debug "configure()"
def updated() {
log.debug "updated()"
response(["delay 2000"] + configureAfterSecure() + refresh())
private secure(physicalgraph.zwave.Command cmd) {
log.trace(cmd)
zwave.securityV1.securityMessageEncapsulation().encapsulate(cmd).format()
private secureSequence(commands, delay=200) {
log.debug "$commands"
delayBetween(commands.collect{ secure(it) }, delay)
