Hey guys, first post in this community, I’m having a little trouble with a wiring setup. I bought a 3 way motion sensor switch (Leviton IPSD6) and although it isn’t exactly smart, it’s still giving me a bit of trouble. From what I can tell, my current configuration is as follows:
Where I want to install this switch at the “master” location, ie. the box that has both the load and the line wires. The “remote” location I will leave as either a dumb 3-way, or upgrade to potentially a smart switch but not sure that is possible without a neutral.
First I tried placing the “common” wire from the dumb switch to the BK on the new Leviton and i installed the travellers to the other 2 lines, but that would only work when the dumb 3-way at the remote was in 1 position.
I was going to use what I saw in this youtube video (see last 1/3 of video, wallbox A): https://www.youtube.com/watch?v=T5cucTA6ioE&t=620s
But it’s slightly different in that they have 4 connections+ground vs mine which is 3 connections+ground. Is there a way to make this work?
What am I doing wrong?
