I Just start here, I have:
1 x Samsung SmartThings Hub
5 x Samsung SmartThings Multipurpose Sensor
1 x WA105DBZ-1 GoControl Z-Wave Siren and Strobe
5 x WADWAZ-1 GoControl Z-Wave Door/Window Sensor
2 x WAPIRZ-1 GoControl Z-Wave PIR Motion Detector
1 x Nest Learning Thermostat 3rd
For now I only connect Nest( I foolwing instrutions Nest Manager 4.0) and Samsung SmartThings Multipurpose Sensor.
I need help/directions to install other sensors.
Those are all standard Z wave devices. You can just follow the general instructions.
You will need to check the owners manual for each individual device to see what you have to do with that device to complete the pairing (âinclusionâ) process. Typically itâs pressing a button on the device, but you need to check each deviceâs manual.
I tried add WA105DBZ-1, â+ Add a Thingâ then start to âLooking for deviceâ after fews seconds show âZ-Wave Switchâ, I remove and try again, only show me âZ-Wave Switchâ.
emersonvier:
Thatâs correct, the siren will initially add as a switch, because it can be turned on and off.
After you get it added if you want to change it to a device type handler that will give you control of more of the siren features, you can do that.
Here is the FAQ for using custom code:
The original FAQ information in this thread refers to the original smartthings architecture, which was in place through the end of 2022 and a little beyond. Custom code was written in the groovy programming language and ran in the smartthings cloud.
As of May 2023, you can no longer add new Groovy DTHâs or smartapps to your smartthings account. So if you came here because of a link in an old forum thread, or on another site, Iâm afraid the Groovy information is no longer usable.
All of this was replaced by a new architecture. Cloud to cloud integrations use the smartthings API. Hub connected devices, mostly Zigbee and zwave, now use âEdge Drivers,â written in the LUA programming language. Hereâs the official announcement on those:
The process for using a custom Edge Driver in the new âŚ
And here is the thread where you can get a custom device type handler for the siren:
I wonât be converting the GoControl/Linear/Vision Siren DTH into an Edge Driver so it will stop working once the Groovy platform is retired, but it probably doesnât need a custom driver.
This is a new device handler for the GoControl Siren, Linear Siren and possibly some other generic sirens. Model: WA105DBZ-1
This device handler supports the following capabilities:
Alarm
Battery
Music Player
Polling
Switch
Tone
MAIN SCREEN
[image]
The main screen displays the current state of the device and allows you to turn on/off the Siren, Strobe, Siren/Strobe and also play the Beep tone.
Be aware that there are settings that can override the functionality of the siren, strobe, and both buttons.
SETTINGS
[image] [image]
Automatically turn off after:
Turns the device off after certaiâŚ
You can ask any follow on questions about the siren in that thread and people will be glad to help you.
I have this sensor also, and canât find the device at all. I have it right next to my hub and press the tamper button for 1 second, nothing, 3 seconds, nothing⌠if I do it for a long time the alarm goes off so I know it is working, any suggestions? It searches and searches and doesnât find it.
