Nice to hear. You make great job.
Regards.
Hi, can You tell me one more thing?
When I test that siren and push ON button
above, it keep play signal. But when I want to stop it I canβt. It refreshing and still beeping. Then I get info about network or server error.
Can that be fix? So I can turn it off with the same button?
Regards.
Hi,
When you turn βOnβ the alarm, does the switch state go to βOnβ or does it stay spinning?
Itβs spinning.
Then it must be that the device is not responding for the defaut_response command.
Without seeing the logs of what the device responds to, I canβt do anything.
If you send me the logs with the CLI I could analyze it
Here is a tutorial on how to install the CLI for windows and capture the driver logs
Itβs possible on Linux?
I think that Linux is also possible.
You can download different CLI versions from here
Releases Β· SmartThingsCommunity/smartthings-cli (github.com)
Yes, there are Linux versions for various architectures.
I donβt know what command to choose.
When I make command: ./smartthings --installed apps it redirect me to browser page with my dashboard:
Regards.
smartthings edge:drivers:logcat
System running the CLI must be on the same network as your hub.
OK, I connect to my hub, I choose Siren Driver MC and I see connected. I turn on siren but thereβs no logs.
Try logging for another driver for testing purposes and/or logging for all drivers (smartthings edge:drivers:logcat -a).
That works:
024-02-27T19:29:29.182857724+00:00 DEBUG Zigbee Thermostat Grzejnik device thread event handled
2024-02-27T19:29:32.139141391+00:00 DEBUG Zigbee Contact driver device thread event handled
2024-02-27T19:29:32.888118058+00:00 DEBUG Zigbee Siren Mc driver device thread event handled
2024-02-27T19:29:39.061039059+00:00 TRACE Zigbee Thermostat Received event with handler zigbee
2024-02-27T19:29:39.124607726+00:00 INFO Zigbee Thermostat <ZigbeeDevice: 0229d707-6670-4dec-98
Tru capture logs when you activate the siren and then when you deactivate it, leave time between actions
I will try tomorrow. Donβt want to wake up my daughter ![]()
Hi, today I test it with command: smartthings edge:drivers:logcat -a
I noticed that I can stop signal when I choose Alarm type - light signal (without sound). Thereβs no light blinking then but it stops.
Install this driver version with CLI command smartthings edge:drivers:install and follow the steps to install driver.
Wait one minute to end driver installation
Try capture logs when push on and off.
If possible try capture logs when push siren only and strobe only
turn On Strobe light and siren or siren only?
logcat not working if you select only Zigbee Siren Mc controller?
βββββββββββββββββββββββββββββββββββββββββββββββββββ
Name Zigbee Siren Mc
Version 2024-02-28T11:47:03.300559505
Now when I install the same driver in cli and try ON siren, there was no sound. Logs shows:
44 324f189f-f73b-4493-98e3-170fdd621b44 Zigbee Siren Mc
45 ab99c2e4-937b-4ff7-8c1f-02bf2c1347f1 Zigbee Smoke Detector
ββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββββ
46 a2f7ec78-14c8-492d-9965-7544b0fc3b68 Zigbee Smoke/CO Detector Mc
47 3f82c4ac-944b-452c-805d-3206a1557bfb Zigbee Sound Sensor
48 40308d12-a2f0-4178-a574-70102c9d0fa9 Zigbee Sound Sensor Ecolink Mc
49 f2e891c6-00cc-446c-9192-8ebda63d9898 Zigbee Switch
50 100106d2-1db9-4909-96b6-c0ea04aaaa6b Zigbee Thermostat
51 8bf71a5d-677b-4391-93c2-e76471f3d7eb Zigbee Thing
52 3724840a-2b1d-4f6b-9683-e8e0155445ee Zigbee Thing [YG] v1.0.2
53 d692640b-402a-4d91-9151-d643ad4771f0 Zigbee Thing Mc
54 4a07c6fd-b0fc-403c-bd07-4cd13f9bef88 Zigbee Valve
55 f82dec82-e5fa-487f-8f0f-22c3e4a8bd89 Zigbee Water Leak Sensor
56 dfdb7a46-3b9a-49af-b08a-2e4624648a42 Zigbee Water Leak/Smoke Sensor 1.7
57 e7070ea0-2ed9-4802-b7e7-5912a75f20fa Zigbee Window Treatment Mc
? Select a driver. 44
connecting... connected
2024-02-28T15:07:07.281640314+00:00 TRACE Zigbee Siren Mc Received event with handler capability
2024-02-28T15:07:07.665089981+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received command: {"args":{},"capability":"switch","command":"off","component":"main","positional_args":{}}
2024-02-28T15:07:07.682632648+00:00 TRACE Zigbee Siren Mc Found CapabilityCommandDispatcher handler in zigbee-siren
2024-02-28T15:07:07.721059314+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB3C0, dest_endpoint: 0x01, profile: 0x0104, cluster: IASWD >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < StartWarning || siren_configuration: 0x00, warning_duration: 0x00B4, strobe_duty_cycle: 0x28, strobe_level: 0x00 > > >
2024-02-28T15:07:07.741054314+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:07:07.799249314+00:00 TRACE Zigbee Siren Mc Received event with handler zigbee
2024-02-28T15:07:07.811291981+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB3C0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xBE, rssi: -51, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x4B, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0010, extended_status: 0x00, zone_id: 0x00, delay: 0x0000 > > >
2024-02-28T15:07:07.841585981+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren -> Woox Siren
2024-02-28T15:07:07.859209981+00:00 INFO Zigbee Siren Mc Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2024-02-28T15:07:07.866018648+00:00 PRINT Zigbee Siren Mc <<< ias_zone_status_change_handler >>>>
2024-02-28T15:07:07.900546981+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-02-28T15:07:07.908979648+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:07:07.938280314+00:00 TRACE Zigbee Siren Mc Received event with handler zigbee
2024-02-28T15:07:07.951264981+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB3C0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC6, rssi: -53, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0002, DataType: Bitmap16, ZoneStatus: 0x0010 > > > >
2024-02-28T15:07:07.972262648+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren -> Woox Siren
2024-02-28T15:07:07.986186981+00:00 INFO Zigbee Siren Mc Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2024-02-28T15:07:08.006075648+00:00 PRINT Zigbee Siren Mc <<< ias_zone_status_attr_handler >>>>
2024-02-28T15:07:08.010835314+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-02-28T15:07:08.021170314+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:07:09.331038315+00:00 TRACE Zigbee Siren Mc Received event with handler zigbee
2024-02-28T15:07:09.346039315+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB3C0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0xFF, profile: 0x0104, cluster: PowerConfiguration >, lqi: 0xC6, rssi: -53, body_length: 0x000B, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4D, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0020, DataType: Uint8, BatteryVoltage: 0x26 >, < AttributeRecord || AttributeId: 0x0021, DataType: Uint8, BatteryPercentageRemaining: 0x48 > > > >
2024-02-28T15:07:09.355565982+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren
2024-02-28T15:07:09.359996315+00:00 INFO Zigbee Siren Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryVoltage
2024-02-28T15:07:09.422603982+00:00 WARN Zigbee Siren Mc The device reported a voltage, but the driver was not configured to handle it.
2024-02-28T15:07:09.427763982+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren
2024-02-28T15:07:09.432348648+00:00 INFO Zigbee Siren Mc Executing ZclClusterAttributeValueHandler: cluster: PowerConfiguration, attribute: BatteryPercentageRemaining
2024-02-28T15:07:09.437767982+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> emitting event: {"attribute_id":"battery","capability_id":"battery","component_id":"main","state":{"value":36}}
2024-02-28T15:07:09.443056648+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:07:09.539224648+00:00 TRACE Zigbee Siren Mc Received event with handler zigbee
2024-02-28T15:07:09.546739315+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB3C0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC6, rssi: -50, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x4E, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0010, extended_status: 0x00, zone_id: 0x00, delay: 0x0000 > > >
2024-02-28T15:07:09.562241982+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren -> Woox Siren
2024-02-28T15:07:09.572557315+00:00 INFO Zigbee Siren Mc Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2024-02-28T15:07:09.591016982+00:00 PRINT Zigbee Siren Mc <<< ias_zone_status_change_handler >>>>
2024-02-28T15:07:09.606901648+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-02-28T15:07:09.616334648+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:07:09.620962315+00:00 TRACE Zigbee Siren Mc Received event with handler zigbee
2024-02-28T15:07:09.625920982+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB3C0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xBE, rssi: -49, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x4F, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0002, DataType: Bitmap16, ZoneStatus: 0x0010 > > > >
2024-02-28T15:07:09.631213982+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren -> Woox Siren
2024-02-28T15:07:09.635904982+00:00 INFO Zigbee Siren Mc Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2024-02-28T15:07:09.641026982+00:00 PRINT Zigbee Siren Mc <<< ias_zone_status_attr_handler >>>>
2024-02-28T15:07:09.645781649+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-02-28T15:07:09.650991649+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:07:26.411156656+00:00 DEBUG Zigbee Siren Mc driver device thread event handled
now I start only strobo but with no effect:
2024-02-28T15:11:58.741027434+00:00 TRACE Zigbee Siren Mc Received event with handler zigbee
2024-02-28T15:11:58.753080100+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB3C0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC8, rssi: -54, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x54, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0002, DataType: Bitmap16, ZoneStatus: 0x0010 > > > >
2024-02-28T15:11:58.773335434+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren -> Woox Siren
2024-02-28T15:11:58.793250434+00:00 INFO Zigbee Siren Mc Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2024-02-28T15:11:58.801170100+00:00 PRINT Zigbee Siren Mc <<< ias_zone_status_attr_handler >>>>
2024-02-28T15:11:58.813353434+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-02-28T15:11:58.818529100+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:11:58.831051767+00:00 TRACE Zigbee Siren Mc Received event with handler zigbee
2024-02-28T15:11:58.843647434+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB3C0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xCC, rssi: -55, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x53, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0010, extended_status: 0x00, zone_id: 0x00, delay: 0x0000 > > >
2024-02-28T15:11:58.851135767+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren -> Woox Siren
2024-02-28T15:11:58.855856767+00:00 INFO Zigbee Siren Mc Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2024-02-28T15:11:58.861484434+00:00 PRINT Zigbee Siren Mc <<< ias_zone_status_change_handler >>>>
2024-02-28T15:11:58.870020434+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-02-28T15:11:58.881159767+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:12:10.121548439+00:00 TRACE Zigbee Siren Mc Received event with handler capability
2024-02-28T15:12:10.148086772+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received command: {"args":{},"capability":"switch","command":"off","component":"main","positional_args":{}}
2024-02-28T15:12:10.164585439+00:00 TRACE Zigbee Siren Mc Found CapabilityCommandDispatcher handler in zigbee-siren
2024-02-28T15:12:10.169470106+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB3C0, dest_endpoint: 0x01, profile: 0x0104, cluster: IASWD >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < StartWarning || siren_configuration: 0x00, warning_duration: 0x00B4, strobe_duty_cycle: 0x28, strobe_level: 0x00 > > >
2024-02-28T15:12:10.198272439+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
Now I push siren & strobo and it works ![]()
both working, there was light blinking and sound beeping. When I click ON/OFF button it stops right away ![]()
So i thing itβs OK
2024-02-28T15:13:52.798363155+00:00 TRACE Zigbee Siren Mc Received event with handler capability
2024-02-28T15:13:52.827468155+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received command: {"args":{},"capability":"switch","command":"off","component":"main","positional_args":{}}
2024-02-28T15:13:52.844447821+00:00 TRACE Zigbee Siren Mc Found CapabilityCommandDispatcher handler in zigbee-siren
2024-02-28T15:13:52.850298488+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> sending Zigbee message: < ZigbeeMessageTx || Uint16: 0x0000, < AddressHeader || src_addr: 0x0000, src_endpoint: 0x01, dest_addr: 0xB3C0, dest_endpoint: 0x01, profile: 0x0104, cluster: IASWD >, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x01, seqno: 0x00, ZCLCommandId: 0x00 >, < StartWarning || siren_configuration: 0x00, warning_duration: 0xFFFE, strobe_duty_cycle: 0x28, strobe_level: 0x00 > > >
2024-02-28T15:13:52.877488155+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:13:52.924282821+00:00 TRACE Zigbee Siren Mc Received event with handler zigbee
2024-02-28T15:13:52.931216155+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB3C0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC0, rssi: -54, body_length: 0x0009, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x19, seqno: 0x0B, ZCLCommandId: 0x00 >, < ZoneStatusChangeNotification || zone_status: 0x0018, extended_status: 0x00, zone_id: 0x00, delay: 0x0000 > > >
2024-02-28T15:13:52.951908488+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren -> Woox Siren
2024-02-28T15:13:52.961044155+00:00 INFO Zigbee Siren Mc Executing ZclClusterCommandHandler: cluster: IASZone, command: ZoneEnrollResponse
2024-02-28T15:13:52.981014488+00:00 PRINT Zigbee Siren Mc <<< ias_zone_status_change_handler >>>>
2024-02-28T15:13:53.001173155+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-02-28T15:13:53.064769821+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:13:53.081030821+00:00 TRACE Zigbee Siren Mc Received event with handler zigbee
2024-02-28T15:13:53.111382821+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> received Zigbee message: < ZigbeeMessageRx || type: 0x00, < AddressHeader || src_addr: 0xB3C0, src_endpoint: 0x01, dest_addr: 0x0000, dest_endpoint: 0x01, profile: 0x0104, cluster: IASZone >, lqi: 0xC8, rssi: -54, body_length: 0x0008, < ZCLMessageBody || < ZCLHeader || frame_ctrl: 0x18, seqno: 0x0C, ZCLCommandId: 0x0A >, < ReportAttribute || < AttributeRecord || AttributeId: 0x0002, DataType: Bitmap16, ZoneStatus: 0x0018 > > > >
2024-02-28T15:13:53.164836488+00:00 TRACE Zigbee Siren Mc Found ZigbeeMessageDispatcher handler in zigbee-siren -> Woox Siren
2024-02-28T15:13:53.180849821+00:00 INFO Zigbee Siren Mc Executing ZclClusterAttributeValueHandler: cluster: IASZone, attribute: ZoneStatus
2024-02-28T15:13:53.212416488+00:00 PRINT Zigbee Siren Mc <<< ias_zone_status_attr_handler >>>>
2024-02-28T15:13:53.251496155+00:00 INFO Zigbee Siren Mc <ZigbeeDevice: 79923fd0-422c-41d1-8a4e-c3fc9b48d5f2 [0xB3C0] (Woox R7051 Siren)> emitting event: {"attribute_id":"switch","capability_id":"switch","component_id":"main","state":{"value":"on"}}
2024-02-28T15:13:53.290865488+00:00 DEBUG Zigbee Siren Mc Woox R7051 Siren device thread event handled
2024-02-28T15:13:56.501161823+00:00 DEBUG Zigbee Siren Mc driver device thread event handled
