hi i have been trying for days to install echosistant but keep running into the same stumbling block i have gone over each step by step instruction from thingsthataresmart.wiki echosistant installation but when i get to the Amazon Configuration lambda function the G U I is completely different and i cant find the options i am supposed to follow ie Configure Triggers
Instead of starting a new thread, ask your question in one of the existing echosistant threads. That way the author is automatically notified when a new post is added, and other people using the same code May also be able to help you.
So ask your question to the following thread and you will get the quickest answer:
And specifically in the case of EchoSistant , have you followed the troubleshooting tips in the community – created wiki? It’s definitely a complicated install, and A lot of people find those of help.
