As the subject says, I’m looking to create a routine that will turn on a plug when temperature in that room is below 65° and then turn it off when the temperature reaches 68°. Is this possible with one routine, or will I need one to turn the outlet on and another to turn it off? Thanks!
You will need 2 routines. One for turn on and one for turn off.
Thanks for the reply! Setting up the routines now.
