Hi everyone,
I’m trying to fully integrate a Tuya Zigbee temperature and humidity sensor with LCD in SmartThings using the “Personal Tuya Devices – main” Edge driver and I’m stuck with the humidity value.
This is the device: https://it.aliexpress.com/item/1005009243616158.html
Device details
Product code on device/box: HS03‑ZI – Tuya Zigbee Smart Temperature and Humidity sensor
Zigbee model shown in SmartThings: TS0601
Manufacturer: _TZE284_9ern5fh
Paired to an Aeotec/SmartThings Hub v3
Initially detected as “Zigbee Thing” with the generic “Zigbee Thing” driver
Driver and profile
Installed the “Personal Tuya Devices – main” Edge driver (Public SmartThings Edge Drivers – w35l3y).
Changed the device driver from “Zigbee Thing” to Personal Tuya Devices – main.
At first I used Profile = Generic, set:
“Temperature sensors” =
1 -
“Humidity sensors” =
2
This created two child devices (child temperatureMeasurement…andchild relativeHumidityMeasurement…) but values were wrong (e.g. 200 °C, NaN or 100%).
Then I switched Profile to “Temperature & Humidity”, which exposes:
DP for Temperature Measurement -
DP for Relative Humidity Measurement
Current configuration
Profile: Temperature & Humidity
Temperature Unit Scale: Celsius
DP for Temperature Measurement: I tried
1(temperature now looks correct, around 19–24 °C). -
DP for Relative Humidity Measurement: I tried
1,2,3, and other values.
What works
Temperature now looks good and tracks the real value on the sensor’s LCD.
Humidity is reported and updated in SmartThings, but always as 100%, regardless of the real humidity on the device display (for example, the sensor shows 64%, SmartThings shows 100%).
Changing the DP for Relative Humidity Measurement changes nothing: humidity remains stuck at 100%, just updating over time.
Debug
The “Debug” card on the device detail view only shows some HTML table style text, not the raw datapoints list, so I can’t easily see the EF00 DP values directly from the app.
Log level set to Info/Debug doesn’t change that card content in a human‑readable way.
Question
Has anyone already integrated this exact model:
- TS0601 / HS03‑ZI / _TZE284_9ern5fh
with the Personal Tuya Devices driver (or any other Edge driver) and managed to get correct humidity values?
I’m looking for:
The correct DP numbers for temperature and humidity for this device, and
Whether any scale/offset needs to be applied to convert the raw DP value to a real humidity percentage (for example divide by 10, 2, etc.).
If a specific profile or a small tweak in the driver is needed (e.g. adding a custom mapping for this manufacturer/model), any guidance or code snippet would be really appreciated.
Thanks in advance for any help or hints!
