Good day everyone, I need some help installing the following dual relay into a ceiling fan canopy:
What I am getting stuck on firstly is what do I connect to the aux wires since it’s being installed in a canopy and not to a switch? I am connecting it to a single wall switch which will remain on at all times and I control the fan and light via ST (on and off). I have it installed as follows: Hot from switch to hot on relay, load 1 and 2 on relay to the fan and light load on the fan, neutral from relay and neutral from fan both connected to neutral in ceiling housing.
I can only put it into pairing mode manually by pressing the pairing button relay button, and when I do only one of the loads work.
What am I doing wrong?
Thanks in advance for your help!
