Haven’t found a definative yes or no if relays in light fixtures can be done. I have a room Single switch when i bought the house controlled both the lights in a room 15 feel apart. Before smart things( like 2006 for me) i put in two of the hunter ceiling fan type wireless switches in that had a fixture module that was placed in the fan/fixture. I have one of each in the room. I now have a smart things hub and would like to convert this setup to smart things but again I would need relays or modules that could go into the ceiling fan/light fixture since it is the same wire that powers both fixtures. I would also like to have any module directly connect to the zwave switches I could put into the way. If anyone knows of an easy diagram software I would put up the diagram as well. So to really state my need Can I do it with this and some zwave plus switches
- Ceiling fan module/relay that i can place in the ceiling that i can connect to smart things hub and directly to a switch so if my hub stops working the switch can still turn on the fan/ and light . Also i don’t need fan speed control i leave my fan on high all the time so just on and off for the light and fan
- Ceiling light module that can also connect directly to a switch and the hub in the ceiling
- Which switches I should use to direct connect. I think any zwave plus switch should work but want to be sure.
I know there is scattered info on this on the community but I don’t see anything to current and was hoping for ideas
