Hausbell smart WiFi plug
No biggie. That’s the really cool thing about SmartThings community. There is always ton of support.
So you will need to download the app from either Android Play Store or Apple App Store. Set up the plug. You then will NEED to set up a scene for the plug to be ON and a scene for the plug to be OFF. I will explain later below
Once you have completed that, you will need to go to your SmartThings account
Go to “My Device” and click “New Device”. For the name you can put whatever you are wanting to name it. Same for the label. Generally these are the same. For the Type you will want to select “On/Off Button Tile”. For the NetworkID you can put the same thing you put in as the name. So my Name was Living Room Fan. For the NetworkID I just put LivFan. You can really put whatever your wanting as long as it doesn’t conflict with an actual NetworkID you have in use.
Your pretty much done. Now you just need to use IFTTT to complete the process. You can enable the channel by finding Smart Life.
Authorize it by signing into the channel with the login you used when you downloaded and setup the plug.
From there you just have to create the applet. You will have to do two (on and off).
You may have to re-authorize SmartThings channel to find your plug so you might as well go and refresh your devices on that channel.
1st applet. . . IF SmartThings plug X turns on THEN Smart Life X SCENE!!! turn on.
2nd applet . . IF SmartThings plug X turns off THEN Smart Life X SCENE!!! turn off
For some reason Smart Life applet really doesn’t discover the devices but it finds the scenes so I just created scenes inside the Jinvoo app for a scene called ON and scene called OFF.
Your done. Go and test.
