Thanks for responding, I ended up up removing mine a couple of days ago and it has made testing with it sooo much easier.
If you listen carefully, can you still hear a faint noise while it’s on?
So there’s still no way to control the siren to only flash the light without the noise?
These things are LOUD.
The first time you turn it on and any time you take the back cover off it will make noise, but other than that you can just use the strobe.
The DTH below has the strobe command and there’s also a setting that allows you to override the “both” command so that when SHM turns on the siren, it will strobe instead.
Excellent - many thanks!
I opened one of mine up and cut the 2 yellow wires going to the speaker so that it no longer makes any noise at all. If the siren is removed, you can have the red light strobe like usual, but you can also turn it on solid. I’ve had no problems with mine, but that doesn’t mean that you won’t so I’m not recommending that you do this.
I also own these (and new to ST) and wanted to know your thoughts, before installing, do you believe this could replace an alarm system? In other words, do you believe the functionality would be at least similar?
I’ve never had an alarm system and had no intentions of ever getting one, so for me, ST works great as an alarm system.
If safety and security is a real concern for you and you already have an alarm system or you’re trying to decide which alarm system to get, I don’t recommend SmartThings.
There are a bunch of topics discussing this, but here are a couple of reasons why it can’t compete with a real alarm system:
It relies on internet so even if you’re paying for the monitoring portion, if you lose internet, they won’t get notified.
If you’re using custom DTH for the siren, door/window sensors, and motion sensors and you lose power or internet, someone could break in and you wouldn’t even know it.
I am willing to take the risk that someone isn’t going to cut off power and then break in to avoid the alarm going off but fair warning
What I am hoping the GoControl sensors and ST integration will allow for is
I understand some of this will require some custom programming but do you believe it is doable with ST and the GoControl sensors?
None of it will require custom program, @ady624 created a powerful new SmartApp called CoRE and it will allow you to do everything that you mentioned.
My DTH for the GoControl Siren does have a chiming/beep feature, but the device’s response time isn’t reliable so sometimes it does a quick beep like it’s supposed to and other times the siren turns on for 2-3 seconds.
The GoControl door/window sensors work great for turning on and off lights as you enter/exit rooms, but the GoControl motion sensors can be a little bit slow to react. They still work, but it may take a few seconds for the light to turn on. Also be aware that once they detect motion, they won’t report no motion until there’s been at least 1 minute without activity. Default is 3 minutes, but the DTH allows you to change it.
I originally tried using the geolocation feature, but I found that if I closed out of the SmartApp it wouldn’t detect that I’ve left or arrived and even when it was open it didn’t always work right.
I ended up getting the Arrival Sensor which costs about $30 and I haven’t had any problems with it. If you get this, be aware that the battery level will rapidly drop for the first few weeks, but my battery has been bouncing between 30% and 50% for several months so it’s not as bad as it seems.
WAF is always a concern, but if you don’t try to automate everything at once, don’t eliminate the manual way of doing things, and show her how to manually turn off the siren if it ever gets stuck on, she should be fine.
Mine went off in the middle of the night once when ST was having state variable issues and the other day the bride came home, Smartthings was having issues, alarm was not disabled and she was unable to turn it off. When it’s screaming 101db at you it’s hard to figure out how batteries come out. She didn’t take a hammer to it but she wanted to. I found it buried in pillows in another room when I got home. Needless to say, no more alarms in my home. I Just turn on all the lights and text the phones if a sensor is tripped. Another alarm issue would cause my WAF to drop considerably. I thinking of using the alarm, muffled, in the garage when the doors are operated unattended.
Steve
If WAF is a concern, but you still want a siren, I recommend going with the Aeon Labs Siren because there’s a button on the bottom of the device that allows you to manually turn it off.
Thanks Kevin. I opened the siren and could really solder a switch real easy. My fear is another middle of the night false alarm. She is VERY TOLERANT of my hobby (even when lights go on/off randomly) but seems to draw the line at the siren. Been here 26 years and no issues. That’s not to say we may not have one someday but our “neck of the woods” is pretty safe. I only installed it because Amazon sent me one by accident.
Steve
Exact reason why I haven’t hooked up sirens. The smartThings platform isnt stable enough for security devices, if an alarm went off in the middle of the night and woke the kids…
I have been considering wiring in a switch as well and leaving the sound turned off.
If you open the siren there are 2 yellow wires that go to the siren itself. Just clip one. I’ve seen where other community members do this.
DISCLAIMER: I take no responsibility if you ruin your siren.
I’ve packed mine with cotton trying to quiet it down for use as the garage door unattended alarm but it still seems loud. Will probably have to see if reducing voltage to the siren works. If not, I guess you would want it loud so someone would know the door was going to move?
Steve
I ended up clipping both wires and removing the speaker from one of mine so now I can use it as a strobe or a solid red light.
I ended up taping a bunch of cloth over the speaker of another one and it reduced the volume a little bit, but the sound still comes out from the other sides.
I’ve also been thinking about reducing the voltage or swapping out the speaker for a smaller one, but I’ll have to do some research before attempting it.
Did you have the device set to only strobe the light when the problem occurred?
No. I was using it as a siren. In my humble opinion, a strobing red light would not deter a thief. I actually had the light completely off and the siren hidden on top of a kitchen cabinet. Didn’t want a thief to find it and the light would draw his attention. A light only alarm might be good for a water leak or some other “notification.” I might reinstall it to notify me of water leaks, supplemental alarm for smoke alarms or my garage door idea. I might just pull the batteries and toss it on the shelf too. It really isn’t at the top of my priority list. I finished all my door/window sensors this week (really nice to have the HVAC turn off when you open a window and turn back on when you close them all) as well as being able to quickly see what windows are currently open. My next job is to set up the motion sensors in the garage to get the very best coverage. I have my normal honey do list too. Not enough time in a day.
Steve
Understood - I’m actually using it as a general sensor and not as a siren/deterrent.
Since I have “both” set to only strobe, I’m hoping if it goes off by accident it will not start the siren.
I have played with this handler and it seems solid. As long as you have it set up for light or strobe and no siren, it shouldn’t go off.
General Disclaimer: this is Smartthings so do anything can happen
Steve
The only exception to this is if you open the back cover of the device.
