Hello…
I have a GoControl/Linear GD00Z-4 garage door opener. It is working with the app but there is about a 5 min or 10 min delay on alerts for open and close.
Any ideas on what I can do to end the delay and have them be more instant?
Thanks,
Rob
Hello…
Thanks,
Rob
I found this to be very finicky also, so I put a standard door/window sensors on the garage door. I trigger actions and notifications based on open/closed state of the sensor.
Reboot the hub and do a Z-Wave repair. You garage controller should also ideally be no further than 30ft from the nearest repeater or hub.
Mine has been working fine for over a year. I recently started having the same exact delay issue when it used to be instantaneous. I changed the battery in the tilt sensor and it is still delayed. I’ll try rebooting my hub and do the zwave repair to see if it fixes it.
