Glass Break Sensor by 2GIG
Has anyone tried pairing this glass break sensor by 2GIG with a ST hub?
2GIG-GB1-345
Or does this only work with 2GIG control panel?
From the technical specs it looks like it operates in the 345 MHz band, and it does not speak zwave nor zigbee. Thus, it is incompatible with SmartThings.
There is, however, this sensor: http://shop.getvera.com/ProductDetails.asp?ProductCode=VSN-ZS5101US
It speaks zwave, which theoretically makes it compatible with SmartThings. You will still need to write your own device handler. I don’t remember anyone here reporting that they have tried this sensor.
