Github Integration Issue (2 Sites?)
I’m having a bit of an issue trying to do the Git Integration,
I managed to do it and add an app i wanted, but it never showed up on my smartthings app, Then I noticed this;
https://graph.api.smartthings.com
Shows the Integration and the App, but doesn’t show my Hub or Devices
https://graph-eu01-euwest1.api.smartthings.com
Shows my Hub and Devices but doesn’t show my Integration (nor does it have the option to integrate) or App
Seems like there are 2 sites here, as a UK user I’m not sure which to use, the EU one doesn’t have the Enable Git Integration link
So the way smartthings work is you might be on a different shard. Each shard has it’s own unique url for its IDE. Easiest way to get to is is:
  1. Go to https://graph.api.smartthings.com/5
  2. Login and then click on My Locations, then click on your hub name.
  3. login again and check my devices and you should see everything there.
You will have to enable the Git Integration after that. I am not sure if it’s available in the UK though.
Ahh doh! fair enough.
If you are on the EU shard then I’m afraid there is no github integration.
ST will NOT be providing it either as there are other things in the pipeline according to ST.
Unfortunately ST are good at saying things are in the offing but nothing ever appears.
