It’s not actually that simple… There’s a lot of different things going on, including the fact that this is an iPhone and that it’s at a variable time.
I think you can probably do this with core, but to be honest I’m not sure. I would ask in the in the core peer Assistance thread and the experts there should be able to tell you if it’s doable.
Hi i believe it is feasible but not really that easy
30 minutes before my alarm goes off - You would require to use something like tasker or putting the alarm time directly into the rule
turn on the lights to 10% - Easy enough
play an audio playlist on a sonos connect amp - don’t have a sonos, cant really comment
open the blinds a little - should be easy, provided u have a blind that is connected to smarthings
set my philips HUE LED strip light plus to blue light at 20% (no bridge) - im not sure you can use this without a bridge, i am unaware if there is a custom DTH for this. But if you had a LED controller, like the FIBARO RGBW controller, it should be easy enough
It’s the iPhone Alarm that’s making it a little harder than what should be needed.
Honestly, people typically wake up around the same time. However, you could have multiple triggers at different times that would simulate alarm timers. Put the various wake up routines in Core Pistons
CoRE Piston 1 (Basic in Expert Mode)
If Alarm 1 Switch (Virtual Switch) is on
When True
Using Location
Execute Piston Alarm 1 Routine
Or
If Alarm 2 Switch (Virtual Switch) is on
When True
Using Location
Execute Piston Alarm 2 Routine
Or
If Alarm 3 Switch (Virtual Switch) is on
When True
Using Location
Execute Piston Alarm 3 Routine
Piston 2
If Alarm 1 Changes to On
When True
Using Alarm 2 and 3
Turn Off
Or
If Alarm 2 Changes to On
When True
Using Alarm 1 and 3
Turn Off
Or
If Alarm 3 Changes to On
When True
Using Alarm 1 and 2
Turn Off
Piston 3 Alarm 1 Routine
Do
Using Lights
Using Sonos
Using Blinds
Using Philips
WebCore is likely to eventually replace core, but web core is still in the early beta stages which means you might have to completely rebuild all of your rules if a new release comes out. And there may be some glitches.
So at this point, Core is more stable but is limited to the mobile app UI. First adopters and tinkerers will generally jump right into webcore. Those who are trying to solve a specific practical problem right now might prefer to use core for now because of the stability.
