There are two different kinds of modes: location modes and security modes. STHM (The feature in the new V3 app which is similar to the old SHM) uses security modes. But the STHM security modes are not exposed to Webcore or Core.
People are using to workarounds for this.
if you only use the default location modes, you may be able to just make the security mode mirrored the location modes. But that generally doesn’t work for people who have custom location modes.
alternatively, you can create a virtual switch for each security mode and turn it on and off as STHM changes the security mode. Then you can trigger your piston off of the virtual switch.
Thanks for replying @JDRoberts
I am using the location mode and not the security mode/status.
I have just been looking at some Webcore pistons and Webcore does seem to still be working with Location Modes.
But apparently the original Core is no longer seeing location modes.
The question is, is it worth rewriting all my old core pistons in Webcore are is webcore just going to be killed soon too?
I migrated Friday and finally got my things ‘mostly’ working again today on Sunday.
So I have around 130~ devices. Mostly a mix of GE Zwave wall switches, Ecolink Zwave tilt and contact sensors, a few iris contact sensors a water cop Zwave valve and then a bunch of SmartThings branded zigbee devices, including water, outlet and multipurpose sensors. I also have a modified contact sensor as smoke with a kiddie relay as well as a bunch of ‘cloud’ devices including those from alarmserver, ring, honeywell and myq.
All of my physical devices migrated as well as automations using those devices.
However, I make use of alarmserver - envisalink- DSC to get my alarm and it’s sensors into SmartThings as well as Lock Manager and that’s where things went south immediately.
I purposely remove lock manager prior to the migration because I wanted to try out the new SmartThings lock solution.
the migration screwed the pooch on all on all of my ‘scenes’ that utilized those alarmserver ‘cloud’ devices that alarmserver brings in. I called Samsung for support because they were just ‘missing’ from the new app, but still showed in the old and in IDE. They told my they’d re-migrate me in 24 hours… been 48 and nothing.
Finally gave up and manually deleted all of the DSC devices that come in from alarmserver via IDE, then reran alarmserver to get them recreated - they then showed up in the new app and I was able to recreate my automations that use the devices
Support = 0, me = 1
SmartThings Smart lock guest access… I’m just going to say what a total piece of crap. It sends notifications any time someone enters a code and that notification setting tied to STHM security settings - so if you want to get an alert when you alarm goes off, you also have to get a notification any time someone entered a code?? Who though that was a good idea?? Next issues, when I rename the code slots, SmartThings immediately resets them to code 1, code 2 the moment they are used. - under history, this should be able to list ‘who’ open the lock and whether it was manual code entry or via app like the old system- fail. Oh and I can’t forget that code management is ‘per lock’ without any synchronization options… seriously!? These devs are just lazy or stupid - not sure which.
Stupid decisions.
SmartThings devs = -3
Fortunately Lock Manager still works for now though it all has to still be managed via the old app.
STHM has zero integration with 3rd party smart apps effectively making my alarmserver setup useless without a workaround… and the workaround isn’t fully baked but it will do for now.
Come on Devs!!! You call this a production ready release ???
People keep mentioning things like this. The migration does nothing to those devices, or other SmartApps. Before the migration they would have worked in both apps and after the migration they would continue to work in both apps.
As I mentioned, my PHYSICAL devices were fine. However, my CLOUD devices were hosed. I understand that they were not SUPPOSED to be screwed, but they were in fact SCREWED.
I’ve deleted EchoSpeaks and Alexa. Installed the New Alexa App after deleting everything in the old App. Actually went pretty smooth. Had to rename a couple of things but all in all, wasn’t that bad.
As of now, I am going through all of my virtual switches created by a couple of Apps and recreating those in the IDE to be Simulated Switches. Tedious process but making it through.
The timeline given, IMHO, has been enough to make needed transitions. Hate I have to go through all of this but hopefully, the future will be promising.
It may not be a ‘default mode’, I had probably created it years ago for only god knows why!
That’s the biggest problem I am having with this whole mess is trying to remember what did what and why.
Its not just the risk of things breaking, its also the fact that there will be NO support whatsoever to help you out afterwards.
I have made the switch 2-3 weeks ago, and have YET to receive any form of support. Either I am being ignored (from within the app), or the Samsung Support doesnt know what to do (“because we are sperated from smartthings”).
Following up on my questions. Anyone has managed to combine an NA location with an EU location in the same account in the new smartthings app ?? Appreciate help or any hint
