Gerda smart lock Gerdalock v3
(MarcinK) #1
Have anybody experimented with Gerdalock v3? It is ZWave Plus and perfectly matches my door lock but unsure if it would work with Smarthings.
Guess I’d need a device handler for it?
https://www.gerdalock.com/produkty/gerdalock-v3
#2
The Gerda lock appears to be a rebranded Danalock. You might write them and ask for a copy of their Z wave certification to be sure.
If it is a rebranded Danalock, then you can use that DTH with it.
I am tagging @rboy on this as he has done a great deal of research into various lock models, and may know for sure.
(MarcinK) #3
This is a great point- they actually look very much alike - let me check if they are the same.
(www.rboyapps.com - Make your home your butler!) #4
Thanks JD. Haven’t seen this specific model and I can’t seem to find any Z-Wave compliance certification documents either for it. It’s very likely a rebranded Danalock like you mentioned.
It should work with SmartThing like a Danalock V3. If you get the lock @Marcin_Karnowski try using this DTH to make it work with ST [RELEASE] Universal Enhanced Z-Wave Lock, Schlage, Yale, Kwikset, IDLock, DanaLock, August Pro, Samsung, Locstar, KeyWe Locks and Popp Z-Wave Keypad Device Handler with Alarm Control, Notification, RFID, Door Sensor and advanced features
After you’ve paired it with your hub feel free to PM me and send me the MSR for the lock (you can find this printed by the DTH or from your My Devices page) and also the Raw Description for your lock from your My Devices page and I can tell you what features it’ll support with ST.
(MarcinK) #5
Thanks- checked with Danalock - it is the same product with different name so all should work - big thanks!
(www.rboyapps.com - Make your home your butler!) #6
It may have a different manufacturers code. If you do get it feel free to ping me and send the MSR and Raw Description so we can enable the custom features for your lock model also, if it’s using the Danalock mfr code it should work fine out of the box with the standard and advanced features with the custom DTH
