Generic Multichannel Z-Wave devices stopped working with new SmartThings app
Oh sorry for lack of info. I was building on top of the comment from soysauce. My scenario is exactly as his. I have several Vision and Monoprice dual relay modules that I used to control two separate devices. After Smartthings Groovy deprivation, I’m looking for alternatives. Was not able too find a Generic Multichannel edge driver. Someone suggested to use Zoom Zen52 driver but it won’t let me select. Complains on “fingerprint” mismatch. I’ve pulled in device info as you requested below. As an alternative, it was also suggested to install “Z-Wave switch and Child MC” driver and use that instead. And that is what I’ve done now. Both Master and Child devices work as before but Status does not get updated. Manually switching devices on/off does not report status to the Hub. Even when device is turned on/off from Hub, it does not reflect correct status. Hope this helps understand the issue.
Device Information:
-Wave Device:
DNI: 0x15
Firmware Ver: 17.2
Library Ver: 6
Zw Protocol Ver: 3.67
Manufacturer: 0x0109
Product Type: 0x2017
Product ID: 0x1717
End Point & Command Class: [1]: MULTI_CHANNEL,
SWITCH_BINARY, SWITCH_ALL, ASSOCIATION,
MANUFACTURER SPECIFIC, VERSION
End Point & Command Class: [2]: BASIC,
SWITCH BINARY
Hi @rizy1976
This device with firmware version 17.2 and 13.7 should work fine with my driver.
Exclude the device with the app and remove the DTH legacy child device if it still exists in the sun app
Re-add it from scratch with my driver with the search option close and it should work.
