nickha
(Nick)
#1
Hi
I have recently installed my first GE ZWAVE paddle wall dimmer. It is connected in and works great (via the ST app). I have used ST for several years
HOWEVER … I am not able to switch the device off manually… I can switch on… make brighter…make dimmer. I can take the brightness down to 1%.
How do you switch off manually ? (instructions say a single press - but that just seems to reduce brightness.
Nick
Single press down should turn it off. If it doesn’t there may be something wrong with the switch.
TN_Oldman
(Don)
#3
Be sure just pushing down like a normal switch.
Press and hold down is dimming. Toggle down is off.
Same for on in up direction.
Kato
(Cristofer Johnson)
#4
Are you using LED bulbs? I went through many till I could find some that would actually shut off.
