I have a GE zwave switch that I’m going to have to reset because it keeps turning itself on in the afternoon and the actual “on” time is set to one minute before sunset. Anyhow, I am currently using the double tap option to turn on and off another zwave switch, which I believe is configured via the zwave association group settings in these devices. I had formerly done this via Smartthings, but I can no longer find these settings anywhere (it has been a few years). Where can I configure double tap in the new and “improved” Smartthings interface?
I followed this (including removing the switch and then adding it back) but I don’t see any additional parameters under Settings after successfully changing the Driver to GE Z-Wave Switch/Dimmer/Fan/Outlet. I have a ZW4001/GE Switch 45637. Where are the instructions for removing a DTH? I think I had setup webCoRE years ago, but I can’t recall any of the details and thought all the automations I setup in webCoRE were no longer functional.
