GE outlet is tripping pool pump reset button, anyway to bypass?
I have a Bestway pool and the outlet pump has a reset button and every time I toggle off my Zwave GE outlet it’s tripping the reset button of the pump wire. So I need to push the reset button of the pump outlet in order to turn the pump on
Any help to bypass this without cutting the pump wire cord?
I have this exact same problem (ge zwave switch and Bestway pump), and I haven’t found a fix for this. I also don’t want to cut the cord and replace the plug. It’s pretty frustrating to have to press the reset button every time. Please let me know if you find a solution.
is the “pump wire” a GFCI? or a circuit breaker?
maybe a “soft starter” would help.
I have the same issue. Did you find a solution?
