Hi, My GE/JASCO Dimmer Blue Light is turned on only when the light is on (Dim Level >0%). I thought that the blue light should be turned on when the light is off. Is there something wrong with my dimmer? Maybe wrong installation?
Current status is saying:
switch: on
level: 82 %
indicatorStatus: when on
If everything is OK with my product, is there a way to change it?
I found the solution, but I don’t know why the default was wrong…
I opened the smartthings app on my mobile and found the device. Then I opened the configuration of the device and changed the “LED Indicator” to When Off (Instead When On).
Thanks for this. I just added my first GE Dimmer (have tons of GE switches) and the default on the dimmer is totally opposite to the default on the switches. I thought I did something wrong too. I had also connected the neutral since I was swapping out one of the switches for a dimmer and with the switch you have to use the neutral, even though in the dimmer instructions it did not specify this as a requirement.
