Garage door based on Ecolink tilt sensor doesn't show up on goodnight mode
I can’t select it to make sure the garage door is closed.
Hey Eaz,
What are you using as the “switch” to actuate the garage door? Can you tell me which device type it is using?
I’m using a Linear FS20Z (shows up as Evolve LFM-20)
Ok, have you gone through the garage door solution setup through the “Doors and Locks” section?
Doors and Locks>Gear icon in top right> Add door>select garage door as the type and then follow the setup.
Sorry for the delay in responding - on vacation.
Yes I Have.
Here’s a summary of the garage door setup:
Switch
Linear FS20Z-1 Z-Wave module
Group: Doors & Windows
Preferences
Name: BMW Door Relay
Smart Apps
BMW Door
Door Name: BMW Door
Door Type: Garage Door
Door Alert If Left Open
Door is: Open
Number of Minutes: 15
Open and Close it Remotely
Connect an Opener?: BMW Door Relay
Edit Door Name Devices
Door Name: BMW Door
Open/Close Sensor: BMW Door
Garage Door Controller: BMW Door Relay
Sensor
Ecolink Z-Wave Wireless Tilt Sensor
Preferences
Smart Apps
BMW Door
Door Name: BMW Door
Door is: Open
Differences between working door and non-working door
Working door uses Smartsensor, non-working uses Ecolink tilt sensor
Doesn’t appear as option under Mode->Good Night!->Open or close garage doors
Main config screen on smartsensor has selection of door state or door open button
Config screen for Ecolink tilt sensor only has door state
