Update (Nov 2026)
• Floor plan mode – Mesh tab → Upload plan… → drag each device to its room; links and routes are drawn on your plan (stored only in your browser). Export / Import layout to move it to another PC or phone
• Click a device → route to the hub hop by hop, LQI per hop (✓ = from the routers’ own routing tables)
• Color by RSSI or LQI; hover shows online / offline; offline devices and stale tables from offline routers are no longer guessed
• Aqara/Xiaomi Switch and Button SD – Aqara switches, relays and buttons now report signal + neighbors
• Tuya EF00 curtain motors now report in Zigbee Multi Switch Light Curtain SD
• Fix: neighbors module refuses an invalid (all-zero) leave request that could drop a router off the network – please update your drivers
• Why the app’s “Connection path” differs from the map: the app shows an old snapshot; the map reads routing tables every 15 min. Zigbee routes change with link quality – both can be right at different times
• Can’t force a route in SmartThings, but you can influence it: add a plug/repeater in between, or re-pair a sensor next to the router you want
• Coming: IR remotes (Moes/Tuya TS1201) – waiting for @otivax, otherwise I’ll build a new driver
Ever discover a leak sensor or door contact had silently dropped offline only when you actually needed it? I built a free hosted service that checks all your SmartThings devices once a day and sends you a list of the ones that are offline.
Features
• Daily message via Telegram and/or Pushover at the hour you choose (your location’s time zone)
• Offline devices grouped by room
• Exclude list for devices that are offline on purpose
• Pick your Pushover notification sound
• Nothing is sent when everything is online
• English/Hebrew UI, works on mobile and desktop
No tokens, no SharpTools
• No PAT or any other token needed – you sign in directly with your SmartThings account, and access refreshes automatically (no more 24h expiry)
• No SharpTools or any other third-party service required
Notification channels
• Telegram – free
• Pushover – one-time purchase of about $5 per platform (after its free trial)
Privacy
• Read-only access (devices + locations) – the service can’t control anything
• One-click unsubscribe deletes all your data and revokes access
Setup (about a minute)
Open the link and tap “Connect SmartThings”
Approve access
On the settings page, connect Telegram (tap the link, then Start in the bot) or enter your Pushover User Key and pick a sound
@Paul_Oliver
Good question. As far as I can tell, Samsung hasn’t published how OAuth apps that other users authorize will be billed, so I can’t give a definitive answer yet.
What I can say:
• You don’t create a PAT or register as a developer – you only sign in to SmartThings through the app’s OAuth flow.
• The API is called under my developer app, so if Samsung charges anyone for it, I’d expect that to be me as the app owner, not you.
• Usage is very light: one check per user per day (device list with health status + room names).
If Samsung’s terms end up requiring something from users, I’ll update this thread. Unsubscribing deletes all data and revokes access at any time.
Mesh tab → Upload plan… → pick a PNG/JPG of your home
Drag each device to its room (right-click to un-pin) – links and routes are drawn on top of your plan
The plan is stored only in your browser, never uploaded
How to use the map
Open the map and sign in with a token (Devices: List + See; add Control for ghost removal)
Click any device → its route to the hub, with LQI per hop (✓ = from the routers’ own routing tables)
Color nodes by RSSI or LQI; hover shows online/offline and last report time
Offline devices no longer get a guessed parent, and offline routers’ stale tables are ignored
Why does the app show a different route than the map?
The app’s “Connection path” is a snapshot – the last route record the hub received, sometimes hours or days old
The map reads each router’s routing table every 15 minutes – the route in use now
Zigbee routes change all the time based on link quality, so both can be right, just at different times
The hub→device path can also differ from the device→hub path
Can you force a route?
No – SmartThings has no static routing. But you can influence it:
Add a plug/repeater in between – the mesh reroutes through it within minutes
Re-pair a sensor next to the router you want – it picks the nearest strong router as parent
Zigbee counts hops: one good direct link (high LQI) beats two hops, even at -80 dBm RSSI
New driver in my channel: Aqara/Xiaomi Switch and Button SD (fork of veonua’s driver) – Aqara switches and buttons now report signal and neighbors.
IR remotes (Moes / Tuya TS1201): I asked @otivax to add neighbor-table support to his IR driver. If that doesn’t happen, I’ll build a new driver.
Fix: the neighbors module now refuses a leave request with an all-zero address (a bug that could make a router drop off the network). Please update to the latest drivers.
