Fortrez Watercop constantly opening closing on its own
Hi,
The smartthings transition has been painful…
I already have the CT100 thermostat problem described elsewhere that keeps resetting the temp after being set which has been logged as a bug with samsung.
Now my main water is getting cut on and off.
It randomly closes, and if I open it, between 1 and 10 minutes later it closes again. or the reverse where it suddenly opens. It’s not hooked up to any moisture detectors and has no routines attached to control it. I have no issues excluding/adding the Watercop to smart things with the fortrez driver, and switching it to a generic zwave valve driver has the same issue.
[Edit: I should add it doesn’t do it when not connected to smartthings so it’s not faulty on its own]
Anyone else having this issue or have suggestions?
Thank you.
It sounds like your valve is actually cycling, not just reporting open/closed incorrectly - is that right? If it’s just the status displayed in ST, it sounds like this issue:
Yes I should have mentioned that. It’s not a reporting issue and actually turning off the water which is quite noticeable :slight_smile:
The Fortez product has always been poor. Long ago I swore off their products. for the last several months “off” is on and “on” is off. this has happened over the last nine months. However, fortrez constantly goes offline, requiring a hard reboot, with this ongoing for years.
i’ve remedied the situation somewhat by having a simple on-off switch connected to the Fortrez which resets the switch, putting it back online, but still recognizing “off” means on.
The upshot is that Fortrez is a terrible product.
