Fingerbot Mode Change on Samsung SmartThings?
so I have Samsung SmartThings Station and I’ve purchased one of those fingerbot from Aliexpress. The instruction from Aliexpress says I should be able to connect by Tuya app as the bot is zigbee compatible but no matter what I do, the Tuya app just couldn’t auto scan the device but somehow SmartThings was able to. So the issue I’m trying figure out is that as a default, the fingerbot presses and pulls back the arm back in one action, but I need to attach a rocker arm to it so the bot can turn on and off lights.
I see that in the Tuya app, it’s supposed to recognize this is an fingerbot and allow me to change the “mode” of the device but I can’t a way to do it on the SmartThings… any help?
To connect the Fingerbot to the Tuya App you would need a Tuya ZigBee hub.
@Mariano_Colmenarejo might be able to give you some pointers.
This device does not work with all its functions natively with smarthings. It need to add to a custom driver.
The manufacturer and model shown in the fingerprints is necessary.
You can view and copy them from my.smartthings.com advanced users.
ST hub & Fingerbot
For some, a Fingerbot may be a TOY. But very often this is the only solution to make a familiar thing - a “smart thing”.
I hate coming into a house where there is only silence. Using Fingerbot and the Geolocation function is the solution to the problem.
Many thanks to the master @Mariano_Colmenarejo. Now it works directly with the ST hub.
It is even possible (this is important) to make fine adjustments. The “up-and-down movement” is now subject to adjustment. It’s wonderful and amazing.
