FIBARO Walli
Hello everybody
Fibaro has just launched new product. will be compatible with smartthings?
These are cool. They are z-wave, so they will be compatible with ST.
Anyone tried and made a DH for the Walli range?
Has anyone tested these products?
I also wonder about the same thing. We’re missing a DH I guess.
Hi,
Just want to inform you that I’ve connected Fibaro Walli Roller Shutter FGWREU-111 to SmartThings successfully using the same Device Handler as Fibaro Roller Shutter module FGR-223 .
Everything seems to work fine. I even mange to calibrate and even reverse the up/down movement. The Device Handler Can be found here :
Hi. Interesting. Have you ever tested Dimmer or Outlet?
I found this link that mentions the Walli:
but it doesn’t work
it the zwave frequency compatible? I think Fibaro use the Europe z-wave stamndard
I’m using Hub from UK. The zwave freq. Is OK for me…
No problems founs
i searched my smartthings app , to fibaro products i saw all the walli series(dimmers, plugs , switches) in there .
we have official support now ?
cause i want to ger rid of my fibaro homecenter , i want all through my smartthings…
Hi, Is there Device handler for Fibaro Walli Controller?.
Hi.
I found nothing of the sort. I use Z-Wave Button
