Fibaro RGBW with ST motion sensor not working
Hi all, this may have bee asked / answered already, if so id appreciate the link to the answer.
Ive got th RGBW hooked up but im only using it to control a srip of white LED no need for colour at all or all the assocatiatd options.
The strip is usd to light some steps, i have a ST motion sensor top and bottom of th steps and just want the light to come on as th steps are used and turn off after a minute or so.
I used the Smart Lightig Smart app to set this up.
When the sensor detects motion the virtual switch turns on but the LEDs dont.
I can turn them on and off in the app no problem. Some searching ive done has shown me that the smart lighting app is no good for th rgbw controller
Can someone please advise a way of doing it or a simple bit of code i can use to make this happen.
I am a very basic code user so id need an idiots guide.
Thanks lots in advance
If you are only using white then you have gone a very expensive way about it.
I did a similar thing and just used a cheap white only led strip, a smart socket and a cheap plugin 12v power supply.
Motion sensor detects motion -> turns on socket -> powers leds via power supply.
Motion stops -> cuts power to the socket.
If you are committed now then I would ask:
What does the virtual switch do?
How is that connected to the RGBW controller?
Iā€™m surprised that smartlighting wonā€™t ā€˜turn on and set colourā€™ or brightness when triggering from a motion sensor
Hi
Thanks for the reply. Yes i see what your saying but i wanted the dimming capability and also for it to be part of my lighting ring which is why i went for the dimmer!
I too am surprised that the smartapp doesnt work!!
The virtual switch activates and shows ā€œonā€ when motion is detected but does nothing else. If i then open the ST app and select ā€œwhiteā€ or slide the dimmer up to 99 then the lights come on.
I tried to alter the level on the smartapp to higher to see if that did it and I had no luck!
Any suggestions?
Bryn
Sorry should have added the virtual switch is ST so its just the built in/ default device set up that is installed when i added the dimmer to my hub
[image1.png]
[image2.png]
[image3.png]
Bryn
This Email was sent from my iPhone.
Ok. I think we are getting confused with terminology.
The motion sensor is not a virtual switchā€¦ we just call it a montion sensor :slight_smile:
In ST a virtual switch is something you can create which behaves like a normal switch but is not related to a hardware device.
Thatā€™s what was confusing me when you said you were setting up a virtual switch.
So, what you actually need is a small smartapp that reacts to a motion/no motion event and turns on/off the RGBW controller to a set level and set colour
Am I correct?
Btw I would not publish your email account here - it can be picked up by spam bots
Best to edit your post and remove it
I forgot to askā€¦ which RGBW controller are you using?
Hi. Thank hadnt noticed my email on it. Sorry i thought a virtual switch was the switch on smartthings that i can toggle on and off rather than a physical wired switch.
Anyway, im using the Fibaro RGBW controller and yes I need something that turns the white on when motion is detected. Im very new to all this so ive seen some code but ive got no clue how or what needs to be edited to make what i need work.
Ive see a few people on various forus asking a similar questioto me, it seems that ST smart lighting app just int good enough for Fibaro gear!
Ok my advice hereā€¦
I have a number of these RGBW controllers and have found the best DTH (similar to a device driver for IT equipment - It allows ST to ā€˜talkā€™ to the device and use all itā€™s features) is the one created by: @codersaur you can find it here:
This thread by @JDRoberts is an excellent howto for using custom code.
After you have installed this then I can probably write you a smartapp to control it via a motion sensor
Thanks i had found this code but need to figure out what to edit (i am totally new to code!)
That woud be graet if you can do that, apprecaite it :+1:
Right that has installed. Ive not edited it becuase to be honest i dont know what to cut out.
Im on a train at th momnt so cant test it until later.
How do i go about simplyfying the screen to remove the colours and presets from the code?
I would not edit it at all!
Once you install a smartApp you shouldnā€™t have to go into this section again.
Butā€¦ you have the facility to use different colours/programs should you ever decide to use them.
Editing the DTH code is not a good idea if you donā€™t know exactly what you are doing.
Also the app I will write may use stuff you edit out and may not work if you ā€˜tinkerā€™ with it.
Now thats installed the smart lighting app has given me more options and seems to recognise that its a colour controller now so Stand by on doing anything until i can check if it works a bit later when im off this bloody train.
Cheers
Right the good news is that it works.
Im a little fussy in that i dont like the app as its a bit clustered but ill live with it.
However the lights snap on and off - taking away the while point of having dimmable LED and dimmable controller. They have a very nice dimming curve and can start very low and fade up and then fade soothly down. Is there any way to write this slow dim into the sequence?
Thanks alot for sorting this :+1:t2:
