Fibaro RGBW Controller (DTH link in post 32, police light smartapp link in post 79)
Agreed, I’m just about finished with my kitchen makeover and have dropped boxes for just such a purpose…now I need to find the tech to wire into place for that.
The Fibaro unit has the input to support this. However, no one has tried this yet as far as I can tell.
I have tried this with a simple doorbell button. It works but is funky. This is what happens. Push the button it turns off, push again it turns on, when on, push and hold down it dims down, release and push and hold down it brightens.
All the above works great… Until you introduce color. So let’s say the strip is turned on as blue, you press the button the blue turns off but the green and red turn on. Now you can double press the button and all colors come on(turns white which for me was too cool of a white) . Then toggle on/off as normal.
So if you just want to use a one color led (warm white or cool white) then you are good to go. Add color (more then one channel to control) and it works but as described is kinda funky.
Thinking im going to get a dimmer switch and associate it with the fibaro. Won’t control color locally but I don’t plan to use that to often so if I want a color change I’ll do that through smarthings.
If anyone is looking for a scene capture replay app for these:
Well… Tried to dim the fibaro with the big switch app. It can only turn it off/on. Can anyone with this controller please confirm by setting setting up a temporary big switch app? I also tried to associate fibaro to a dimmer switch using a mimimote. Fibaro won’t associate :frowning:
I ordered a Fibaro RGBW.I happen to have 5050 led strips as well as WS2812.
Will the WS2812 work with the app/custom device type?
Moreover as the rgbw controller accepts analog inputs, can we use a Sharp GP2Y0A21YK0F (IR proximity sensor)
so that when we are in front of it to open the led strips?
I have seen the capability “sensor” in the code?How can we implement that so that it shows app in the app with the option to have it on or off.
On =automatically opens to a predefined scene or color
off=manually open/close the lights or through ST apps
This seemed like an interesting challenge, so I gave it a go. Linked below is the GitHub for a Virtual Fibaro RGBW, which is just the @wackware device with the zwave removed, parse emptied, and a couple extra events for the SmartApp to subscribe; and a small SmartApp to mimic the virtual commands out to to a group of real slave Fibaros. I don’t actually have any of the strips yet, so I was testing using the virtual device code linked and two Fibaros devices with no physical device.
@Sticks18 @wackware or somebody else who has this answer this question? I can’t see well today, and I don’t have this device, so I’m not sure what’s going on.
He’s saying he tried to associate with the Minimote but now big switch won’t Dim, it will only turn on and off.
One thing I will mention, is that association works backwards from what a lot of people think. When you do the button presses you need to do Minimote, target, trigger. So if you’re turning a lamp on from a motion sensor, for example, the sequence is Minimote, lamp, sensor.
And of course both devices have to support the wave Association.
Anyway, I don’t have the fibaro, and I can’t read the docs today, but that someone else might Be able to help.
Thanks for trying to help @JDRoberts. I just wanted to add when I change the device type of the fibaro to a dimmer switch the big switch app then dims. Also when I tried to associate I did associate in the correct order as jdroberts pointed out and the Minimote light shows a proper association however the dimmer switch does nothing when I dim/turn on/off. Has anybody else tried to associate the fibaro and have success? The fibaro has so many options I’m not sure what the association is controlling. Maybe this is configurable in the device type?
Thanks for any help you can offer
I just purchased an RGB+WW (Warm White) LED strip. Hooked it up to the Fibaro RGBW controller. Using the Fibaro controller device type supplied above in this thread I see no change between “Soft White”, “Daylight”, “Warm White” and “White”. All four of these “presets” have the same RGB lights on a cool white color and the WW LEDs aren’t on. Any suggestions?
can you post installation instructions for a novice?
I tried to add a new SmartApp in the ST IDE and got the following error:
No signature of method: script14345866584781584831286.metadata() is applicable for argument types: (script14345866584781584831286$_run_closure1) values: [script14345866584781584831286$_run_closure1@31eff4b0] Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)
Similar error when trying to install the virtual:
No signature of method: script14345863587431657176927.metadata() is applicable for argument types: (script14345863587431657176927$_run_closure1) values: [script14345863587431657176927$_run_closure1@21936a68] Possible solutions: getMetadata(), getState(), setState(java.lang.Object), metaClass(groovy.lang.Closure)
Were you trying to install a smartapp or a device type?
What lights did you use? I need a ton of lights to do all of our cabinets and I was thinking of using:
These lights will be used:
  1. Built-in 7’ x 6’ china cabinet
  2. Counter tops
  3. Upper cabinets with Glass doors
SUPERNIGHT DC24V 10M 5050 Flexible RGB LED Strip Light Kit, 32.8ft LED Tape, 600 Units 5050 LEDs, Non-waterproof LED Light Strips + 24V 5A Power Adapter + 44Key IR Remote Controller by SUPERNIGHT
Unable to get my lights to work.
If I use the original controller that came with the lights, they work.When I connect the Fabario unit in place of the original controller, the lights don’t work.
This is what I did:
  1. Install Device Type = “smartthings-devices/fibaro-rgbw-controller.groovy”
  2. Connected Fabario controller to power supply via connector
  3. Added my Fabario controller to SmartThings
  4. Plugged my LED lights into Fabario controller
  5. From phone, turned on Fabario controller
These are the lights I have, SUPERNIGHT DC24V 10M 5050 Flexible RGB LED Strip Light Kit, 32.8ft LED Tape, 600 Units 5050 LEDs, Non-waterproof LED Light Strips + 24V 5A Power Adapter + 44Key IR Remote Controller by SUPERNIGHT
no luck.
Found my issue.
The White wire from the lights needs to tied with the “12/24 VDC”. This video is pretty good explaining how I got to this.
Below is finally a video link to my pool light install using the Fibaro RGBW Controller. The lights along the top of the pool are two RGBW strips wired together while the waterfall lights are two 24" rgb lights.
When the waterfalls are off, I typically use the controller slider to remove the “color” from the LEDs. This basically turns off the waterfall lights and just leaves the white lights on behind the pool. That way they match the landscape lighting. I have them come on at sunset and go off at midnight, The landscape lights are controlled by my pool automation controller, so they are separate from the Fibaro system. All in all, I think it works pretty well. Now I just need to convert the pool light from halogen to RGB or RGBW LED to get the colors to all sync up.
https://vid.me/2bxO
Smartthings + Fibaro + Pool = Way cool pool!
That is awesome.
Can you post falls and pool controller mfg/models?
Sure, the waterfalls were Brilliant Wonders 24" LED Waterfall. For pool automation I am using the Jandy/Zodiac AquaLink RS 6 Control System RS-P6, and iAquaLink WiFi Interface Kit IQ20-A.
This is awesome!!
Great job @fraserjr
Definitely keep us updated :slight_smile:
Any suggestions on how to active “Flash the Police” LED pattern when SmartAlarm turns on the siren?
