Hi All,
I have just ‘aquired’ a Fibaro Motion Sensor.
I already have one and it is working flawlessly.
The problem I am having with this one is that it only reports the lux value once after a reset.
I have scoured the forum and have downloaded numerous Device Handlers but it is still the same.
I have changed parameter 40 to 2 so that it should report changes. (On my existing sensor this is set to 100 and reports small lux changes).
When I reboot the sensor (3 presses on the button) it resets and reports the current lux value. If I then move it in front of a light the value changes to the new light level. Then nothing. I can cover the sensor so that it is dark, but nothing reports.
The new sensor is "zw:S type:2001 mfr:010F prod:0800 model:1001 ver:2.06 zwv:3.67 lib:03 cc:30,84,85,80,8F,56,72,86,70,8E,31,9C ccOut:30,31,9C"
I see nothing in the logs and when I look under the recently tab I see 72 $(unit)
For my working sensor I see 72 lux
Not sure if this is significant but thought I would mention it.
EDIT: I have also tried changing the parameters so that both are identical. No joy.
The app shows the last reported value as 72 LUX
EDIT 2: Parameter 42 is set to 60 so I should see a lux report every 60 seconds under the recently tab. Nothing.
EDIT 3: Looking at the logs, everything is being reported apart from the Lux level.
Any ideas/thoughts anybody?
Thanks in advance.
