Hi all,
I’m looking at buying a few of the Fibaro motion sensors. I’ve read that there are issues with firmware versions when connecting to Vera, do the same firmware issues apply to ST?
Thanks in advance
Hi all,
Thanks in advance
I’ve got 5 of them and they all work great! No firmware issues here…
All sensors relay information consustently as well ( lux, temp and vibration)
Out of interest which device type are you using? I recently added a Fibaro motion sensor and I cannot get it to consistently relay lux, temp and vibration.
I am using the default device type from ST. Try the following,
Once you do any or all of these , kill the ST app and log back in . You should see it reporting everything correctly.
Also, Try doing all this by jeeping the sensor very close to the hub (10-12 feet).
