Fibaro FGRM 222 - Roller Shutter
Hi,
I have a Fibaro roller shutter. I want to stop the curtain using my minimote but with the button controller there is no way I can specify stop since the fibaro roller shutter was recognized as on/off switch only
Has anyone make the fibaro roller shutter work on US Hub?
Hi Bee_Jay,
I’m having the same problem. Could you get your’s solved?
Regards,
Jogi
Hello. Button is on/off device. Roller shutter works like a dimmer. 100% is closed, 0% is opened. I use it with Google home asking it dim to X % and it works. Other workaround is if you set up dedicated % for button actions. E.G. up/down for push and 50% for hold. If you use Fibaro button, it has double and triple push states means another 2 levels what you can define.
I have the same problem with the V3 hub.
Do you in the meantime have solved this. If yes, can you tell me how?
There’s a device handler written specifically for the Fibaro Roller Shutter 2 available in the thread linked below. However, if you want to try the method discussed in the post you replied to, you can change the handler used for any device by logging in to account.smartthings.com, clicking My Devices, clicking on the device, clicking Edit, and then choosing another device handler from the drop down list for Type. Note that community created device handlers like the one linked below won’t be in that list until you manually add them.
Thank you very much for your reply. Problem solved. I’ve just paired successfully my fibaro shutter device with the DTH you referred to.
My Roller shutter uses a rocker switch. Once you hold the up button it goes up, until the height you want and once you hold the down button does the same for down.
I do have a a Fibaro FGRM222 and I have many years to re-check if it works but I believe with that kind of switch the Fibaro doesn’t work.
Have you used it with rocker switches that have to be held so that the roller shutter actually goes up or down?
Any suggestion for a device that can make my roller shutter smart?
Hi , I have the FGR 222 roller shutter with a UK v2 hub and it works good. The only thing is when the device loses and regains power, it behaves weirdly and sometimes open up the shades without even any command to do so. Anyone faced same ? Any idea on how to fix this ? As power failures on the device are quite frequent and it’s very inconvenient to have the shades open or close at times when you haven’t triggered any command
Regards,
Fab
