Hi, I’m automating the curtains in my home and have tracks with a Dooya DT52S motor along with Fibaro FGR-223 Roller Shutter 3. I’ve added a Device Handler and added the Fibaro units to SmartThings. All wiring is correct and I can manually open and close the curtains fully from the SmartThings app, Alexa and manually using momentary switches.
What I’m unable to do is calibrate the Fibaro 223. I’ve found a couple of threads on various forums but can’t find any solution - altering parameters makes no difference. When starting calibration (3 x 3 second switch activations or using the B button on the module) - instead of going open, close, open, the curtains just drive to the open limit, stop and won’t complete the calibration. The result is that the position shows as incorrect and I usually have to press the manual switch twice to get it it moving. After messing round with one set and getting nowhere I replaced the 223 with a 222 (using the same Device Handler) and that worked first time. I’ve now tried another brand new 223 and motor in a different room but am getting the same results - the 223 just will not calibrate. Can anyone offer any advice other than to stock up on the older 222 model - I’d really like to get this working with the same module throughout.
